A4 gearing with ATI?
Would I gain anything spending $2000+ on the gears and T/C. Would that money be better spent toward better rubber?
Would the best plan be; ATI then wider tires/rims then gears and T/C?
I do realize a tranny would be figured in at some point. Im sure it will let me know when it wanted to be replaced.
Please lend me your setup experiences..
Do yourself a favor and have your tranny hardened when the blower is installed. As long as the tranny is out the converter can be upgraded very easily.. Save yourself some downtime and some labor charges and get everything done at once.
As for gears .. Believe me when I say you wont miss your 2:73's..
Cheers,
Mark
I know for certain 2.73's would have been ZERO fun even with the blower. One thing I've noticed is that I "usually" don't even see boost, the gears & LT's have made such a difference in the car! Pulls nicely, but 3.73's may have helped a bit more.
Nice thing about the ATI, when you want the power YOU GET IT!!!! My car pulls like no tomorrow. A buddy of mine with an '03 Cobra (547rwhp) says all the time when he drives my car that it hits like you've just been kicked in the ***.
Gotta love that. I'm sure more people will chime in, look forward to hearing your final decision.
Sure it'll go eventually, but until it happens I'll keep driving it like I stole it!!
My A4 is holding strong, small steps grasshopper, I m in the situation your talking about the 2.73 gears just take so much of the neck snap out of it. I m planning on 3.42's and the widest tire I can get under it without tubbing. I believe that the 3.42's will only agrivate the tire problem because with the S/C and 3.42's you will get into boost faster and harder. As I drive mine around I find myself seeing where and what speed I can still spin the tires at. Get the 3.42's a good wide set of street tires and an S/C and you'll crap your pants. ATI+3.42+12"pilot sports=pooop in pants.Sure it'll go eventually, but until it happens I'll keep driving it like I stole it!!
Is that a proven formula?
Mark
I disagree- for now anyway. I've had my stock tranny in my 481rwhp car for approx 5k miles now with absolutley no problems. I'm not drag racing it every weekend, but I'm not taking part in the local parades either. I drive the car fairly hard- seem to get under WOT acceleration every time I drive it.
Just my .02.
I've got my 2.73 gear still in my car- Is it as fun as a 3.42 or 3.73 car???, no I'm sure it's not, but it's still very fun and seems to pull like a **** to me. Not to mention that it's a lot more driveable at low speeds than a 3.42 or 3.73 car, IMO.
If your a huge drag racer than it's a huge deal- get the 3.42's or gear of your choice. Me? My 2.73 is fine for now and is plllleeenntty fast.....although I do plan on upgrading eventually, just not on my immediate "to do" list. Don't let people talk you out of having a 2.73 blown car- there's nothing wrong with it.
Cheers,
Mark
I do agree the 2.73's should go though, I went with the 3.42 and stock converter.
I can tell you that a high stall converter with street tires would be a waste of money with my combo.
The converter and big tires that bite will take out the A4 in a hurry but the change to a higher gear ratio will lessen the load on the driveline.
Right now the biggest bang for his buck is the gear change and it will benfit him down the road with or with out the S/C install.
Oh and I have about 15000 miles on mine since the S/C install.
From what I gather new wider rubber will be the death of it for sure. Thanks again for all the help
Mike
As someone mentioned before "how would I know about 2.73's being fun?", yes that's COMPLETELY TRUE. But, I have had other cars that went from 2.73's right up to 3.73's and the improvment was well worth it.
Truth be told, my original plan was to simply get the D1-SC installed at ECS.... THE END .... not!! While there I got "talking" with Chris & Doug and next thing ya know it's getting the gears, t/c, and LT's Kooks headers w/hi-flow catpipe.
Looking back, I'm still very glad I did it. My car's exhaust sound with the Corsa Indys is simply AMAZING!!! You cannot believe how many people pull the ole head spin to see where the heck that sound came from.
You cannot go wrong with the blower, pick a good quality kit from ECS or A&A and you're off to a fantastic start. Be sure to keep us posted as the "medicine" starts to flow!
When I made my decision, based on information from members of this forum, I went ahead and purchased the 3.42's. If I had it to do over again, I definitely would have gone with 3.73's.
Someone mentioned the higher gearing would be annoying at lower speeds? I am not sure how this is the case? If anything, higher gears, such as: 3.42's or 3.73's will be annoying at highway speeds since the RPM's will be higher. . . In my opinion, the gears and the converter are absolutely essential to make the car perform.
Afterall, who wants to spend the money on a SC only to be beaten by a car with far fewer mods? I suspect, in a quarter mile run, a Vette running 3.73 gears and a decent converter will run nearly identical ET's as a SC only car? From stop light to stop light, the car with gears and converter will likely win!
My .02 cents, go with the gears and the converter first. Then add the blower when you are ready to also build the tranny. Regardless of which choice you make, I look forward to seeing the results!
Mike
Great choice- that's exactly what I did.
Where 3.42's start feeling a bit tame is on the street. This could be just my setup as I'm running an SS3600 T/C, but maybe others can chime in here for ya.
