KB Boost-A-Pump Question
Old Sep 8, 2004 | 10:58 AM
kromberg's Avatar
kromberg
Default KB Boost-A-Pump Question
Should the pressure sensor be installed into the intake manifold or the intake ducting after the S/C? Also what size are the threads? They look to be 1/8" NPT. TIA.
Keith
Old Sep 8, 2004 | 11:44 AM
VETZILLA's Avatar
VETZILLA
There is a line coming off the front drivers side of the intake manifold that reads boost and vacuum, that is where I tied mine into and it works fine.
Old Sep 8, 2004 | 11:57 AM
The DBK's Avatar
The DBK
mini-hijack.
Vetzilla you've got a PM.
Old Sep 8, 2004 | 02:08 PM
kromberg's Avatar
kromberg
Would the sensor not get a more accurate reading of the pressure if it where installed directly to the intake manifold rather than being installed using the tee adpater off the small hose line?
I have a sheet metal intake and was thinking about installing the sensor right ext to the MAP sensor on the back.
Keith
To KB Boost-A-Pump Question
