Heard something a while back that Magnusson is going to be coming out with a bigger/more improved Maggie. Anybody heard anything else on this?????? Is it balogne or true?????
the current Mag is 112ci, the next version will be a 122 so not much bigger buy hey, its still bigger than what we got now. Heard it comes out in January.
if you have a stock block, non forged, why would a bigger one be better? Would the intake charge be cooler? I am plenty happy with my 5-6 psi boost and hope it lives long and happy ...but I do like the thought of more power
I beleive it will lower IAT's given same amount of boost.
I don't work for Eaton, but as an analogy, the smaller M90 models seen in the Series II and Series III GM V6s have gone through improvements to bolster power gains w/o even increasing size. The 1995-2005 Series II V6 S/C make 240hp, require premium fuel, and make 7.5 psi boost.
Between calibration and blower improvements, the 2004+ Series III 3.8L in the Grand Prix makes 260hp on premium, can run on regular, and makes 9 psi peak boost. One would imagine the added boost means more heat that would inevitably mean detonation at low rpms on regular fuel since it's non-intercooled (beyond the correctability of calibration, i.e., hovering too close too ignition miss or running too rich). But blower improvements somehow counter the added heat of compression.
So if Mag's 122 cid incorporates internal improvements, it may be worthwhile for even stock shortblock folks if intercooling is used.
After reading this post I called a friend of mine a Magnusun. The larger displacement SC is to come out for the C6 only. There are several improvements that need to be made since the C6 has a higher compression ratio than the C5. So the good new... C6 owners should be able to get a Mag with larger displacement, 10 Cubes, that will be more efficient.
Bad news... us C5 guys have the current model and that is about it. Although a high performance Mag is expected out sometime late next year, it will not come in a kit and is to be for "offroad use only".
BLAST!!!!! Why cant we have a roots or twin screw blower like the snakes????!!!! If someone made one capable of 600rwhp, with all that torque as well, i'd be all over it like a dog on a bone!
Now the real news:
There are not any plans for a 122 supercharger for ANY of the Corvette applications. The 112 is MORE than enough for any stock LS1 motor to handle, and more than acceptable for any larger cubic inch LS1 if calibrated properly. Don’t be fooled by the rumor mill, I know for a fact that there are NO PLANS for a 122 supercharger for the C5/C6 application. I have seen a LPE 427 with a Magnuson 112 make in access of 600 rwhp....I think that is more than most could handle on the street!
Now the real news:
You heard something different than I did, buf if what you heard is true.....
It's because of this philosophy that Magnacharger is going to lose ALOT of business in the very near future. You snooze, you lose.
Magnuson was never able to get an approval for the original Magnacharger on the C5 LS1 and we all thought they would. It turned out that the original intake manifold cant pass a California restart test. At least that's what I heard.
I have never heard of a 427 with a mag. When I asked if anyone ran this setup pretty much everyone agreed that there is no way a maggie can flow the kind of air a 427 would need.
The intake manifold on the stock C5 is plastic and not prone to transfering heat from the heads unlike the aluminum manifold that the magnacharger has. The revised Magnacharger Intake has addressed this issue by providing a thermal barrier (so they tell me).
Upon restart the heated air in the intake manifold wont let the AFR adjust quick enough to pass the test, once going the intake is cooled by fresh air and operates per spec.
My Regal GS has a Maggie M90 on it from the factory. The intake manifold had a 2x2 square right under the supercharger outlet where coolant flows through. It's to heat up the intake charge on start up. Must do wonders for my IAT's.
