It seems that the acceleration is strong until I get to WOT and then it seems to fall off (almost like it flattens out). Other times it feels fine and pulls well, but not through all the gears. I can't really see any black on the intake like the belt's slipping, but it sure feels like it.
It seems to drop off while I'm accelerating up through the rpm range. It starts off strong and then it just seems to go flat when I reach upper rpms (above 4000).
Sometimes, I'll leave off a bit on the throttle and it'll pick-up again.
check the tubing on the front of the Mag and make sure it is out of the way of the BOV. Sometimes it will snag and you want get full boost. I know from experience
but if you have full travel on that actuator then your getting KR
Any ideas?
are you running the magnacharger tune by any chance?
I have stock prings, with 23,000 miles,, my car hits 6000 rpms so fast its stupid,,,my only problem is hitting the rev limiter,, I dont seem to have any valve float (yet)..If its starving for fuel, it wont last long,, better get it checked out,,,make sure it aint lean
I had Second Street Speed do the install and had they try to check for problems also. They did another dyno pull and it still made the same Hp (420rw).
I am running the MagnaCharger tune. Is there a problem with it?
Man if you are running the canned tune, you are in hell and guess who's the snowball! I have the I/C Magnacharger and I can assure you you are running LEAN, not to mention a dozen other things that super chips does. My initial readings were 22% lean R bank and 18% lean L bank. With the intercooler iat's were 150-160 due to leanness. They h
ad my RWtq set at 650 which negates active handling and TQ control.
Please get a professional tune from someone who knows the Vette PCM.
If you don't know anyone e-mail me and I'll put you on to someone who knows what their doing.
Its knock retard pulling timing. Mine did the same thing.
