TTi Stage X Baseline Dyno Sheet!!!!!
A little background, as you know I have been blowing up rear ends etc while helping George with the new Stage X. The last one grenaded at 18psi on good fuel and it was a total loss.
I have made a change in housing and ratio. Because of this I decided to re-base line my setup. I was trying to hold out on posting the sheets so I had the comparison of Pump vs Race fuels and more boost at the same time but its just not going to happen right now.
The drive train consists of a forged 348, stock crank with average ported (flow 270CFM) heads to give me 9.2-1 compression, LS2 intake manifold with 90mm TB, reverse split cam and now a Getrag 3.73HD rear. No trick short belts, methanol, Torco (although in the summer I use it) stock water pump and even full exhaust (B&B tri-flow, not the best for power but I like the sound).
I drove it their (45 min. drive) and made 3 pulls.
This is my PUMP GAS (Sunoco 94)Tune that I have raced on and put 1200 miles on so far with 13-13.5 PSI boost. Boost controller was set soft to keep the tires from spinning on the dyno. I logged Air fuel, its pretty stable at 11.5-11.7 using my wideband, They use a tail pipe sniffer, which I hate and don’t trust. Hrm I think that is it. Oh, except for the preemptive strike, the drop in power at 6800 rpm and up is very intentional.
Phil
.Mark
.Mark
But Yellohhhh, you still thinkin' about a Stage X? Come to the dark side!
.Mark
1.Jersey Jay
2.Yano
3.
4.
5.
But Yellohhhh, you still thinkin' about a Stage X? Come to the dark side!I contemplated it, but I decided to have ECS install a 3.1 pulley and and alky system, and re-tune my car instead. While I'm not at the power level you X guys will be at, I am over 500 rwhp, so I can't complain. Over 450 rwtq from 3300 rpm to 5600 rpm so it's a blast to drive! With the money I saved by going this route, I plan to pay my car off this year, and buy a C6 Z06 sometime in 06 when the initial feeding frenzy dies down. Then, back up to ECS for some dished forged pistons and stage X for the Z...
2.Yano
3.
4.
5.
1.RoadRebel- Beat on hard and put away wet.
2.DiyNoob- Self installed production kit #1, Quote from Noob "I'm having the best FI time of my life with it "
3.Vetzilla-self installed, just begining to enjoy-First A4
4.Lesboost- Currently in mad scientist mode putting motor together.
5.Yano- Waiting on install in the mountains where the air is clean and thin.
6.JerseyJay- Currently begging ESC to work faster on his huge project.
7.Enderz06-Currently begging me to finish this Turbo TA
I am working on.8.Boogielake-Currenty waiting for George to work faster
9.Boost Master- Crazy Canadian waiting for George to work faster
10.Forum Member- Will ask if if he wants to be added ot this list. Closet Stage X waiter.
11.Non forum member currently being installed at TTi.This car will be interesting.
So far 7 kits are in forum member hands in various stages installation. If I missed someone, sorry..my mind is not what is used to be.
Better not wait for a Z06 to long. After 06 things are going change again
To think, this was the thread that started it all!
[/IMG] [IMG]
[/IMG]Phil,
Do you this this is a major build for the ECS boys?
They did alot this past week and as you fellow forum members can see here's my almost not complete project.
I should have results within the next couple of weeks for all of you too see.
I just have to make sure I keep Chris off the net so he can work on my car!
