pcv catch can and problems!
1st problem i noticed is, driver side valve cover pcv hose (closest to winshield, about nickle size) either came loos or was blown loos and oil was all over the place.
2nd there is a screaching noise that happens after the car is running for a min or two ,that go's away if you take off the oil cap...seems to be pressure in the system.
3rd, i noticed the car was running and sounding off, after a fill up from a dif gas station. muffled missing sound....30% reduction of power. i don't no if its the pcv/ catch can set up or gas related probs or both.
4th the car ran fine for 3 weaks with the same pcv set up....why prob now?
This is my pcv setup= a)valve covers teed by factory are going into the top of amw catch can.
b)exiting out the side of can and giong into check valve and into side of manifold behind throttle. body.
c)pass, front v line is capped.
d) ati air box line is capped.
e) i was told to take off the valve cover breather and put the oil cap back on.
Thanks for any input!
Does it screech at idle with oil filler cap on? If so try keeping the cap on and remove the check valve from the line. You only need it when in boost and testing it in the driveway won't produce boost. Then tell us if the screech still persists.
What was the part number of the McMaster carr check valve? I'd like to know what the cracking pressure is.
• Cracking Pressure: 0.3 psi
The line from the catch can should go to the port on the manifold behind the the TB. on the pass. side with the check valve in between.
Then you need a fresh air intake for air movement so I use the line on the front of the rt. vc down to the ATI air filter with a CH. air liquid seperator in it. (diriction of flow is up to you, I prefer the C/H flow)
Then add a breather cap to the oil fill and your PCV system will function all of the time whether your under boost or normal driving.
The way your hooked up now will never vent your cc.
Here is a dumb idea but just for giggles make sure the check valve air flows TO the intake.
(not the throttle body, like stated befor...i edited the first post)
I took of the check valve and put the oil cap on and the screech noise went away.
I looked in the air bridge and it looks to have more oil vaper residue than before....i may just be parinoid about that!
I noticed the metal tube under the throttle body has nothing on it...is that ok
One question is when you remove the factory PCV valve where is that...i am not sure if that was removed in the past...is it the black tube attachment that goes into the manifold? the reason i am wondering,is with the check valve and the pcv valve both on...it is causing to much restriction....that why i hope the pcv valve was off!
what do you recomend...next?
Drcoffee makes a good point in making sure the flow direction is correct on the check valve, but you said the car ran fine for 3 weeks?
The metal tube under the tb is ok to have nothing on it since it's normally connected to coolent. (sounds like someone did a coolent bypass).
What I don't understand is the oil in the airbridge
Do a compression test! This dosen't sound good
Also do you feel air blowing out the PCV line while disconnected? A: yes
"i dissconected the pcv valve behind the throttle body and there is vacume.
I did get air flow from the catch can exit line...is that bad?
How do i check if the rings are bad?"
Yes this shows that you have a pressurized crankcase at idle and that is serious. Check the engine oil for color, you may have bad rings, bad head gasket, etc. You need a compression test.
I'd call a tuner close by to trouble shoot the problem.
Good luck.
