CR math
Old Nov 2, 2004 | 12:51 AM
boblackhardtop's Avatar
boblackhardtop
Default CR math
I used to have a 422 MTI dry sleeve w/ 11.25 CR, flat top pistons and the MTI stage 3 heads.
I have now used that set of heads in my Darton sleeve 427 w/ 22cc dished piston, my question is what's my current CR ?
Before I do FI I'll probably go w/ the AFR 225 w/ either the 67cc or 76cc depending on what my current CR is.
Anybody w/ the formula for calculating the CR ?
Old Nov 2, 2004 | 08:04 AM
RoadRebel's Avatar
RoadRebel
Formula for compression ratio
(CylVolume + ChamberVolume) / ChamberVolume
cylinder volume = pi/4 x bore^2 x stroke
chamber volume = cylinder volume / compression ratio - 1.0
dont forget to calc the volume of the head gasket and add the chamber volume
If milling heads
displacement ratio = cylinder volume / chamber volume
amount to mill = (new disp. ratio - old disp. ratio / new disp. ratio x old disp. ratio) x stroke
Also, this is still very crude as it doesnt take into account, deck height and top compression ring to piston deck volumes. but will get you close.
Phil
Old Nov 2, 2004 | 09:03 AM
FRC Tom's Avatar
FRC Tom
A little something I put together that might help.
http://www.c5frc.com/calculators/Com...Calculator.htm
Old Nov 2, 2004 | 11:14 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
That's pretty cool. Thanks for the link.
Old Nov 2, 2004 | 05:50 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
Thanks, it's a big help!
Old Nov 2, 2004 | 07:32 PM
boblackhardtop
So what's the bore & stroke of a 427
4.1x / 4.xx ?
Deck height ?
Old Nov 3, 2004 | 08:46 AM
FRC Tom's Avatar
FRC Tom
4.1x / 4.xx ?
Deck height ?
4.120 x 4.00 for most.
Old Nov 3, 2004 | 06:27 PM
boblackhardtop
Thanks Tom,
Looks like w/ the 22cc dished pistons and the .054 cometic my CR is at about 9.1:1
To CR math
