Nitrous users, how did you mount the bottle...
Old Nov 17, 2004 | 05:30 PM
ROJO99's Avatar
ROJO99
Default Nitrous users, how did you mount the bottle...
In an FRC body? Have any pics?
Old Nov 17, 2004 | 07:35 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
I've asked three times on the forum. Finally got fed up and spent some time of the phone with the guys from TNT (I've got a F1 kit with a 15lb bottle). I'm gonna mount the bottle with the valve facing to the passenger side and on a lockable-hinged base/platform in the rear center compartment. So I can accesss wiring and other things underneath
Old Nov 17, 2004 | 07:44 PM
vegasredz06's Avatar
vegasredz06
ill get you a picture in sec,, i have to find it
Old Nov 17, 2004 | 07:45 PM
vegasredz06
http://images.andale.com/127/121/64...Picture_040.jpg
http://images.andale.com/127/121/64...Picture_051.jpg
http://images.andale.com/127/121/64...Picture_052.jpg
http://images.andale.com/127/121/64...Picture_043.jpg
http://images.andale.com/127/121/64...Picture_050.jpg
i dont which one, it is but its on of those pictures..
Old Nov 17, 2004 | 07:47 PM
vegasredz06
http://www.z06vette.com/forums/showt...t=tnt+pictures
its here ,, look for it in the first post
Old Nov 17, 2004 | 07:49 PM
vegasredz06
ttt
Old Nov 18, 2004 | 08:21 AM
ROJO99's Avatar
ROJO99
Great info, Thanks. What safety precautons do you have, I.E. window switch?
Old Nov 18, 2004 | 10:45 AM
HP_Addict's Avatar
HP_Addict
Old Nov 18, 2004 | 11:15 AM
99Z51R's Avatar
99Z51R
St. Jude Contributor '04
Heres a pic of my buddies(1 NASTY Z), took a lot of work but this is how he mounted his in his Z06. I was thinking the compartment in a FRC wasn't the same as a coupe and thats why he made this up, my coupe's is mounted like marlochris's. Maybe he'll chime in with updated pics. with his bottle, very nice set-up
Eric
Old Nov 18, 2004 | 11:20 AM
ROJO99's Avatar
ROJO99
So with the mounting's shown is the bottle visiable? Can the compartment cover be in place?
Old Nov 18, 2004 | 12:19 PM
vegasredz06
i dont have any saftey switches , i tried to install the msd rmp switch,, i could not get it to work...(not really your electrical guy)
i just hit the juice from 3000 rpm and on,, i like it better anyways having full control of the kit....you just have to watch the first to second shift , it comes instant.,.
the best run i have is 11.55 at 124.61 on a horrible short time of 1.87 , so high 10's is very possible with ET streets.
Old Nov 18, 2004 | 12:21 PM
vegasredz06
oh and i had my bottle mounted in the compartment from side to side , but i was having problems with the n20 getting pushed against the wall of the bottle , when i was hitting the gas,, it was pushing the n20 against the wall and would come on and off, so i mounted the bottle facing the front of the car,, ended that problem, i get all the juice in the bottle even the last pound ...
Old Nov 18, 2004 | 01:29 PM
99Z51R's Avatar
99Z51R
Here's mine, The cover fits fine, the bottle is mounted at such an angle and the siphon tube has been moved so that it is towards the left rear of the bottle so you never miss out on any juice when your getting on it. My MSD and WOT are mounted in battery compartment.
Eric
Old Nov 18, 2004 | 11:42 PM
vettjunky's Avatar
vettjunky
What wire did you tie into for the WOT??
Old Nov 19, 2004 | 08:53 AM
99Z51R's Avatar
99Z51R
If I remember right it was the blue wire at the throttle position switch on my 99.
Old Nov 19, 2004 | 10:10 AM
HP_Addict's Avatar
HP_Addict
I was having the same problem and changed my mounting like this:
No problems since changing it.
Old Nov 19, 2004 | 10:54 AM
vettjunky's Avatar
vettjunky
Thank You, That confirms what I've been hearing. I'll post some pictures of a Diamond Plate mounting platform made to mount one or two bottles.
To Nitrous users, how did you mount the bottle...
Old Nov 19, 2004 | 11:29 AM
ROJO99's Avatar
ROJO99
So I can mount the bottle in the rear compartment and it be hidden. What about line routing? I do not want to cut or drill ETC. thru the body.
Old Nov 19, 2004 | 02:27 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
It is quite possible to hide the bottle although it is tight. Here's mine. It's not the prettiest but again, it's not for show, it's for go. and no one sees it when the cover goes over it anynow. I had to use only the lower bottle mount near the top because the top bottle mount made the bottle angle too high for the cover to fit on. You'll have to fab some type of false bottom to mount the bottle bracket(s) to that press fits into the compartment bottom. Also, as mentioned above; the angle, both horizontally and vertically, will be mininal. If I were to re-do it I would have angled the bottom of the bottle towards the rear more but I wanted as much room for an opener as possible. I had to make it so my valve was sitting level for the cover to fit which meant I needed to take the valve off the bottle and adjust the siphon tube so it was in the ideal place to draw nitrous from while under acceleration. I had surging problems as well until I got a bottle heater. At 1100 PSI all the N2O is certain to be liquid.
You should check out http://www.johndennington.com for more tips on mounting, line routing, etc. as well as http://www.hotrod.com/howto/3447/
HTH
Old Nov 19, 2004 | 04:59 PM
vettjunky's Avatar
vettjunky
No the one I build definitely isn't the hidden type. It's more of a show piece. It actually replace the stock cover. It goes on just like the stock cover but it's made of diamond plate. It has compartments for the bottles to sit down in, and at the correct angle. A ten pound bottle with bottle opener clears the convertible top when it's down if you have a convertible.
