Car 99% Complete update
ATI F1R Procharger 3.80 pulley, A & A Stage 2 Single Intercooler, Stage 3 heads, Cometic Gaskits, Pro M Maf(awesome), 383 Lunati Stroker with a LS6 Block, Meziere Electric Water pump, Custom Cam, 8 rib setup, 60lb fuel injector with custom fuel lines, Racetronic fuel pump and Keene Boost a pump, Jesel Shaft Rockers, LSX Fast intake, 90mm throttle body, ARP Head Studs, Double rolling timing chain, Stage 3 Spec Clutch, 3.73 gear with hardend output shafts, Ron Davis radiator with oil cooler, G2 Headers, Hurst short shifter, brake line lock, Eradispeed crossdrilled rotors, Tigershark frontend kit, spoiler on back, heat induction hood, complete custom interior, CCW wheels 18" front and rear with 295 on front and 335 on rear.
That is the majors that was done on the car - I have a complete audio system upgrade that consists of Jl Audio XR speakers for the front and rear, JL 500.5 amplifier powering everything, custom enclosure with a JL 10W3, Kenwood 911 dvd flip out touchscreen monitor and a rear view camera.
Thanks for all the input as this was being built. I will post pics of car, engine, and dyno graph in the next day or so.
Steve
Best of luck and post some pics! Your ride sounds real sweet.
Congrats on the setup.
Are you running 6 rib or 8 rib?
What level boost are you using with 3.8 pulley.
We want pictures....
Thanks,
Jon
I will get pics up by tomorrow. I think you all will find the MAF and setup under the hood extremely interesting.
