ATI SC problem, please help!
Removing the belt is pretty easy. You just put a socket on the tensioner (15mm I think) and load it up to get enough slack to slip the belt off (I usually slip it off the water pump). Do the same thing when going back on.
Sorry, I'm learning.
1. Andy's setup
2. ECS setup
3. New ATI setup
Each of these brackets will address the problem. The new ATI bracket is very nice. For the best performance, you can go with either the A&A or ECS setup.
If I were you, I certainly would not drive the car any further. If the belt breaks, your engine will overheat immediately. You need to get it switched out before driving and getting stranded.
VR
1. Andy's setup
2. ECS setup
3. New ATI setup
#5 the new PTK Twin turbo kit too.
I agree, dont drive your car. My Vortech blew bearings too, I cut the belts to the SC, and had my tuner come get my car. Dont want to risk more damage to the unit or your car.
You should be good to go once you change setups.
The install should be a 15 minute job.
Here is a belt diagram with a blow up of the idler area for reference.
1. Get the car on ramps.
2. Put a socket and ratchet on the tensioner pulley (labeled in the blowup area of the diagram). The (15mm) socket goes on the bolt in the center of that pulley. Push it towards the blower and it will create slack in the belt. Now at the same time (having two people helps) reach down under the water pump (H20 pump in diagram) and slip the belt toward the front of the car and off the water pump pulley. This will allow the belt to have a bunch of slack so that you can take it off all the other pullies and get it off the car. It will most likely require you to get under the car to get it to clear all the stuff that it gets caught on.
Now loosen the 4 brass nuts that have spacers near them (the short round tubes keeping the two sides of the blower bracket apart with the pulley in the middle).
Now you will be able to change the idler out by just removing the one bolt that has the bad idler and spacer on it. The bolt goes all the way through and has the brass nut near the motor. I think it is 9/16 on both ends.
It should be obvious how to put the new idler on.
Tighten all the nuts on the bracket back up and then put the belt back on.
Belt goes on in the reverse of how it came off. You will need to crawl under the car to get it on the crank pulley. Get it on everything but the water pump. You have to do the same thing with the tensioner as you did when taking it off, but you will be slipping the belt back on the water pump this time.
Sorry, but it is hard for me to imagine how someone could not do this on their own.
quicksiler,
thanks for taking the time. I will give this a try. It looks a bit complicated for me but I'll try it. I'm still waiting for ATI to reply back on the part. I hope I get it before deploying out again. Thank you
Thanks everyone.
How tight does the belt have to be? Is there some sort of guage that I need to use to determine the tightness?
Even when your not under boost the belt is still slipping slightly causing it to shread. The original ATI set up gives you about a 30-40% wrap on the main pulley(depending what size pulley you are using). Even when I stepped down to a smaller belt all I did was wear down the surface of one of my idler pulleys about 3/16".
There is a groove in the pulley now as wide as the belt. You can see I now have close to 80-85% wrap on the S/C pulley.
This is the ATI set up minus the 3rd idler on the left. Notice how little of the belt is making contact with the main pulley so you can see how even when your not under load the belt could still slip some. These are also the 2 of the larger 3" pulleys that someone spoke of in this thread.
If its dust, it depends on how much dust???? If it is a lot than that is indicative of a problem. Does the back of the belt look burnt? Do any of the pullys appear to have burned belt on the surface area? If so that would be the pully that is most likely seized. The good new is, that there are lot of forum members on here that have had or have the ATI procharger...so you get a lot of free diagnosis. I don't know what I would do without the Bimmer Forum, Diesel Forum, or this Corvette Forum. Lots of great info. Even Hyundai has a forum.
Thanks everyone for the "how to". I'm still waiting for parts. How do I know when the belt is tight enough when reinstalling?
