Backfires at Cold Start-ups
Old Dec 17, 2004 | 01:51 PM
IRVINEWS6's Avatar
IRVINEWS6
Default Backfires at Cold Start-ups
My car backfires when I start it in the morning. I have a supercharger and my A/F ratio is 11.5;1, so I know the backfiring is from too much fuel at start up.
Is there something that can be changed in the tuning to eliminate this problem at start up, but without effecting my A/F with warm starts, cruz, and WOT?
Other than cold starts, the car runs great!
Thanks,
James
Old Dec 17, 2004 | 03:10 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Have you done non-WOT tuning? Mine ran super rich at idle, popped on cold startups until it went into closed loop. I installed a wide band O2 and tuned it myself driving around town. I also noticed on mine that I ran really rich and my LTFT's would be down in the -16 range when 0 is perfect. It is now tuned to where my LTFT (Long Term Fuel Trim) is between 0 and negative 1 at almost all throttle conditions (except for PE mode where it goes into the set PE program).
Sounds like you need some around town driving tuning done.
Old Dec 18, 2004 | 05:47 PM
Joe@REM's Avatar
Joe@REM
4th Gear
You need to tune your drivability. 14.7:1 should get rid of your problem. it should only dip into the 11's under boost conditions.
To Backfires at Cold Start-ups
