Come On Tuners!
Old Jan 19, 2005 | 03:31 PM
Pickleman's Avatar
Pickleman
Default Come On Tuners!
With all the talk about High HP Vettes! Why doesn't somebody modify either the traction control computer or engine management computer to "Facilitate" the launch sequence as does Ferrari on it's newer models. Nothing is ever easy, however the C-5 uses a fly by wire system. It's really all in the computer as witnesed by the extroardinary 0-60 times if the new 430 or Enzo!
Limited throtle ie: in first (50%)and second (75%) (not unlike feathering the throttle)! Delayed HP not unlike what a Nitrous controller does. This could almost be set up like a Power Programmer with adjustability as everybody's needs would be slightly different depending upon engine, FI or normal, tire size, altitude etc.
VISUALIZE AN ELECTRONIC STOP ON THROTTLE ADVANCE!
I'm not asking for a F.1 suspension control system here...just a progressive limitation on HP!
Not unlike the action of a progress nitrous control or a Boost Controller!
The Same only Differesnt.
I'm sure there are 100 reasons why this can't be done!
Why not find.........One Way to Do It!
Respectfully
Pickleman
Old Jan 19, 2005 | 04:22 PM
RoadRebel's Avatar
RoadRebel
ITs allready in place..
Its called traction control..TCS for short.
The TCS parameter can be modified to do exactly as that import you speak of.
Phil
Old Jan 19, 2005 | 04:57 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Phil check you IM please
Old Jan 19, 2005 | 05:44 PM
3XBlack6spd's Avatar
3XBlack6spd
Someone fill me in? I thought running the TC on a boosted car was a boad Idea, In fact it says so in my Vortech User manual?
Anyway.....What other option have youguys come up with?
Old Jan 20, 2005 | 02:46 AM
Cscokd's Avatar
Cscokd
Phil
Phil, how do you modify the traction control parameter?
John
Old Jan 20, 2005 | 07:42 AM
RoadRebel's Avatar
RoadRebel
LS1 edit..
HPtuners to name a couple.
Phil
Old Jan 20, 2005 | 10:14 AM
Cscokd's Avatar
Cscokd
LS1 edit..
Phil
I have HPtuner software, but I didn't notice anywhere to manage traction control...just A4 stuff.
Old Jan 21, 2005 | 07:42 AM
RoadRebel's Avatar
RoadRebel
What version..
Look in torque managment section.
Has max allowable torque and the full retard tables etc.
The managment model is both active and reactive. The active uses the model and data within to control power to the tires before wheelspin. The reactive portion is after the sensors have detected spin, at that point its a lookup table with timing retard etc used to re-establish positive contact with the road surface.
Phil
Old Jan 26, 2005 | 01:30 PM
Pickleman's Avatar
Pickleman
Default Traction control and HP Tuner
As soon as I get my car back witht the AFR's I'm going to give this a try!
I have HP Tuner and would appreciate any feedback available from any one else giving this a try!
Pickleman
Old Jan 26, 2005 | 02:22 PM
slamar1's Avatar
slamar1
Traction control cuts fuel when the wheels spin, correct?
On boosted applications this does not sould like a good thing
Old Jan 26, 2005 | 03:09 PM
Pickleman's Avatar
Pickleman
Default So Who's Right!
Well............................So can you limit HP W/O cutting fuel FLOW?
Excellant input!
That's one of the reasons I wanted to control the Fly By Wire System!
Questioning!
Pickleman
Old Jan 26, 2005 | 03:52 PM
RoadRebel's Avatar
RoadRebel
TCS only commands Timing..Has a window to pull 47 degrees out. It doe NOT impact fuel or apply the brakes.
Mello was doing some playing as its not snowing there.
Phil
To Come On Tuners!
