Manual Trans 1-4 shift eliminator
Old Jan 25, 2005 | 11:43 PM
turbosupra18's Avatar
turbosupra18
Default Manual Trans 1-4 shift eliminator
I found this unit that eliminates the 1st to 4th gear force shift we have to deal with. Does anyone have/know someone who has installed this? Does it work?
link:
http://www.westcoastcorvette.com/sho...tail.cfm?id=90
Old Jan 26, 2005 | 12:01 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Yes there is part called the CAGS Eliminator which allows you to switch into any gear when you want. The light on your dash will still flash on, but you don't have to pay attention to it.
The install is simple about 10 mins when the car is up on ramps. You can find instructions by going to
http://97vette.com/howto/cags/
Good luck many MN6 owners have it done already.
Old Jan 26, 2005 | 12:08 AM
Cajun99's Avatar
Cajun99
Are you kiddin'?!? Of course...most nearly everyone I know with a six-speed has one...including me.
And...Yeah, it absolutely works. If you take more than five minutes installing it...you're moving tooo slooow.
Old Jan 26, 2005 | 12:14 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
It's actually a 20 ohm resistor that takes the place of the selonoid on the tranny. But buy the eliminator it has all the right connectors to keep things clean. Worth the $15 to $20.
Old Jan 26, 2005 | 12:23 AM
GrayC5's Avatar
GrayC5
Looks very similar to mine. Should work fine.
Old Jan 26, 2005 | 12:32 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Have you met EnglandGreen yet - he speaks Supra!
Old Jan 26, 2005 | 12:48 AM
turbosupra18
ok, tell me if my understanding of this install is correct:
mid america shifter bypass: http://www.madvet.com/shop?frame=1.101
install instructions: http://97vette.com/howto/cags/
a) new small connector connects DIRECTLY to transmission.
b) the piece removed is connected by a wire coming FROM the harness.
c) this original unit connected at the transmission connects to the new large connector
d) secure large connector to the car
Question: so why is the large connector have two parts? Does it have only one connection port or two?
Old Jan 26, 2005 | 01:02 AM
HummelS's Avatar
HummelS
The easiest way to eliminate the skip-shift "feature" is to run it up to about 2K RPM in first before shifting....
Old Jan 26, 2005 | 04:44 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
CAGS was my first mod. It works well and makes around town driving alot easier.
Old Jan 26, 2005 | 04:50 AM
USA-VET's Avatar
USA-VET
Old Jan 26, 2005 | 05:54 AM
This was the first mod I did to my car when I bought it. Easy install and it sure is nice to be able to select the gear you want when you want it.
Old Jan 26, 2005 | 06:04 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The instructions are correct. The reason for the second part is so that you don't have to leave the original connector hanging exposed to the elements. So, you unplug the connector from the tranny. Plug in the CAGS eliminator to the tranny. Plug in the original connector to extra plug on the CAGS eliminator.
Paul
Paul
Old Jan 26, 2005 | 06:07 AM
C5naples's Avatar
C5naples
Buy it . It will make your in town driving much more enjoyable. Easy to install. I bought mine at www.thunderracing.com
Old Jan 26, 2005 | 06:48 AM
Dark-Knight's Avatar
Dark-Knight
It works, quick install, was my first mod. Hated the skip shift!
Old Jan 26, 2005 | 08:03 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
It's a minor mod worth having, especially if you have to drive in alot of traffic and can't get the rpm's above 2000 to shift to 2nd. This mod, will let you shift to 2nd when you so desire.
Old Jan 26, 2005 | 09:29 AM
vette_fanatic's Avatar
vette_fanatic
Got it spank new on ebay $11.99+$4 shipping. turbosupra18 its very east to do , take it from someone who got 2 left hands . . .
Old Jan 26, 2005 | 12:41 PM
SavPrato's Avatar
SavPrato
100%
To Manual Trans 1-4 shift eliminator
Old Jan 26, 2005 | 03:20 PM
MSGvette's Avatar
MSGvette
easy install
Old Jan 26, 2005 | 03:34 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I don't have it, I don't need it, and I don't want it! I'd rather shift at a higher RPM and listen to the Corsas growl!
Old Jan 26, 2005 | 11:44 PM
turbosupra18
Sounds good to me then. Thanks for the advice all! Have any of you driven the auto? Is it any fun to drive?
