New rotors going on...
Old Jan 25, 2005 | 11:52 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Default New rotors going on...
Been looking at these for sometime now, when I learned fire path on the
2 piece matched the caliper width (rear) and Nate had a GP going on, I
had to do it. I think they look great!
I'm going to do the install myself. Any tips, comments, suggestions or
walk-thrus are welcome and appreciated!
Old Jan 25, 2005 | 11:54 PM
GrayC5's Avatar
GrayC5
Very nice!
Old Jan 26, 2005 | 12:05 AM
CUlookin's Avatar
CUlookin
mine are going on too, would like some tips too
Old Jan 26, 2005 | 12:07 AM
USA-VET's Avatar
USA-VET
http://forums.corvetteforum.com/showthread.php?t=845827
Old Jan 26, 2005 | 12:29 AM
Vegas Vette's Avatar
Vegas Vette
I installed mine about a year ago. It is quite simple to do. the rear is a bit tricky due to the E brake. Just follow the direction for the bracket install on the rear fo the +2 rotors. jusy remove the calipers and brackets and off the come. Good luck
Old Jan 26, 2005 | 12:31 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Those look sweet!! even better on the car
Old Jan 26, 2005 | 06:52 AM
Nice looking rotors. Good luck with the install. Should look great on your car.
Old Jan 26, 2005 | 07:10 AM
Evil-Twin's Avatar
Evil-Twin
Now is a perfect time to make sure your ebrake is adjusted properly... make sure the shoes match the drum diameter by turning the star adjuster until the rotors barely go over the shoes.
Old Jan 26, 2005 | 07:44 AM
Automag928's Avatar
Automag928
Look nice!
Old Jan 26, 2005 | 08:16 AM
RWH's Avatar
RWH
SWEEET!, Let's see some pic's after the install.
Old Jan 26, 2005 | 08:57 AM
Boozman's Avatar
Boozman
Sweeeeeeeeeet
Old Jan 26, 2005 | 08:59 AM
Morzoff's Avatar
Morzoff
Very Nice
Old Jan 26, 2005 | 09:01 AM
jrose7004's Avatar
jrose7004
Those will look great!
Old Jan 26, 2005 | 10:00 AM
Vetteran's Avatar
Vetteran
Thanks Bill! Woudn't have thought of that.
Old Jan 26, 2005 | 10:11 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
I'm curious to see how the rears will look since they seem even bigger than the fronts. I'm still not sure if I'm going to buy the 1 piece rotors or the 2 piece ones since the 1 piece ones are actually lighter. Could you post up close up pics of how they look once you install them? Thanks!
Old Jan 26, 2005 | 03:02 PM
MSGvette's Avatar
MSGvette
Goos luck with install
Old Jan 26, 2005 | 06:52 PM
Vetteran's Avatar
Vetteran
Thanks Brian, my search didn't pull this one up.
To New rotors going on...
Old Jan 26, 2005 | 07:15 PM
Vetteran's Avatar
Vetteran
Originally Posted by alex1217
................. actually lighter. Could you post up close up pics of how they look once you install them? Thanks!
Will do Alex!
Old Jan 26, 2005 | 07:55 PM
Evil-Twin's Avatar
Evil-Twin
This is directly from Baer Brake systems. I asked my friend about weights:
Hey Bill,
This is what I got.
Stock rear rotor 13.75lbs ( this is the small rotor )
Our rear 2pc 15lbs ( this is the the 14 inch rotor )
Our rear 1pc 14lbs ( thicker fire path ) small rotor
I don't have a stock front rotor
Our front 2pc 14lbs 12.75 in
Our 1pc (we cast these really thick for durability) 22.5lbs
Hope this helps!
Rick Elam
Baer Brakes
Old Jan 26, 2005 | 09:41 PM
Dark-Knight's Avatar
Dark-Knight
They are going to look great!
