Ram Adjustable Master Clutch Cyl Ques...
I am in the midst of a Ram 980 VDS install w/Ram Adj master clutch cyl. (Also replacing pilot bushing and installing new GM clutch slave and LAPD remote bleeder)
Anyone have tips as to how to initially adjust the Ram Adj master?
I have the stock GM Master out and it appears as though the length of the Ram Master is about 1" longer out of the box. Is this a good starting point or should I make the length of the Ram match the GM unit that I just removed from the car?
Anyone have a good URL or thread that describes the process of properly adjusting the Ram Adj master clutch cyl?
Thanks in advance!
Dont see how to lock or move this thread so here's a link to same ques in tech section:
http://forums.corvetteforum.com/show...p?p=1549573928
