Duds - Klasse Clear coat
Old Jan 27, 2005 | 02:22 PM
duds's Avatar
duds
Default Duds - Klasse Clear coat
I have used Klasse AIO (all in one) and Klasse SG (Super Gloss) on my BMW with great results. Does anyone have any experience with these products on their Vette?
Old Jan 27, 2005 | 05:45 PM
GrayC5's Avatar
GrayC5
Check with the Folks in the Car Care Products section of the Forum and they should be able to provide you with most all the info you need on these products. Good luck.
Old Jan 27, 2005 | 06:16 PM
No, I've never used that product. If it works good on your BMW, it may work fine on the Vette (I know, different standards for the Vette ). Try it on a panel and see what you think. If it doesn't look good or hold up well, you can always take the wax off and reapply something else.
Old Jan 27, 2005 | 06:19 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
good luck
T
Old Jan 27, 2005 | 07:55 PM
Laguna Blu's Avatar
Laguna Blu
All in One works fine. It's very easy on and off, which I like. It isn't very good at removing contaminants but rather excells on a clean smooth surface. In my opinion it doesn't last real long but you can apply it and remove it twice as fast as paste wax.
Old Jan 27, 2005 | 08:59 PM
Killrwheels's Avatar
Killrwheels
Originally Posted by Pewtavert
It works fine. It's very easy on and off, which I like. It isn't very good at removing contaminants but rather excells on a clean smooth surface. Also doesn't last real long but you can apply it and remove it twice as fast as paste wax.
sounds like he is talking about the AIO by itself. I have never gotten less than 4 months protection with it used on wifes previous Supercharged Regal GS and current CTS. SG is a pain in the keister to remove but is basically bulletproof. Alot of us on the car care forum use AIO to clean chemically and then use other sealants like UPP, Blackfire, and Wolfgang for the final coat. Using Sonus Spritz will also help to keep AIO and/or SG at optimum protection and adds gloss with each us, great QD.
To Duds - Klasse Clear coat
