I wanted to remove my wheels to clean and can not find the KEY.
The manual says that the Key is located in a depression in the trunk rail directly under the left rear compartment cover. I removed the cover and lift the carpet up and there is a small depression. Is this the right place or did GM put it somewhere else?
You may look in any of the back compartments, the glove box, etc. If you had someone else work on the car and remove the tires, they may have changed the location.
