[Z06] under hood light
Old Jan 27, 2005 | 07:05 PM
john5's Avatar
john5
Default under hood light
hey guys,any of you had a problem with the light under the hood not coming on.The light bulb looks ok,any ideas
Old Jan 27, 2005 | 07:10 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
It's happened to me too. Check the connection, follow the wire, goes down by the air cleaner.
Mike
Old Jan 27, 2005 | 07:49 PM
Brian Laser S4
Guest
Posts: n/a
Mike
Same here but haven't looked into it, if it added power, it would be fixed
Old Jan 27, 2005 | 08:36 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
Yep, same here. Bulb looks good but light won't come on.
Old Jan 27, 2005 | 09:06 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
mine too WTF? Fuse maybe?
Dave
Old Jan 27, 2005 | 10:19 PM
texasredc8's Avatar
texasredc8
There are some other lamps on this circuit....... do these work okay on your car??
1) Vanity Visor Lamps
2) Map Lamps
3) Glovebox Lamp
also.... AutoDim mirror is on this circuit (if you have this option)
If these do work, this would rule out a fuse or relay problem. I'm guessing the on/off mechanism inside the underhood lamp housing could go bad due to corrosion. If the above three lamps work, then I would say you have either a wiring problem from the relay to the lamp, or a bad assembly.
Old Jan 28, 2005 | 02:59 AM
john5's Avatar
john5
thanks for the info
Old Jan 28, 2005 | 07:08 AM
dragon84's Avatar
dragon84
WTF, mine too. You all made me just go out side in the dark and check..... You'd have thought stuff like this would not fail after having a car a year, thanks GM.
Old Jan 28, 2005 | 09:38 AM
dezcapt51's Avatar
dezcapt51
Mine does it sometimes too - I just tap it and it comes on
Old Jan 28, 2005 | 05:42 PM
Bad Machine's Avatar
Bad Machine
From: Rude, Loud and Aggressive! ECS Twisted Racing, "How fast do ya wanna go?"
Same here.
Old Feb 1, 2005 | 03:54 AM
radz0hh6's Avatar
radz0hh6
Most definitely loose connection
Old Feb 1, 2005 | 05:45 AM
Z-ZANY's Avatar
Z-ZANY
I disconnected mine.Does nothing anyway as far as illumination. My hood is open all winter to keep battery on trickle charge.Same as my c4 will never hook it up again.
Old Feb 1, 2005 | 02:27 PM
3XBlack6spd's Avatar
3XBlack6spd
2) Map Lamps
3) Glovebox Lamp
None of mine work? Then Again I have a toggle switch to Kill all the Rear lights wired in, just in case maybe thats why?
To under hood light
