redtop battery support ?
Old Jan 29, 2005 | 03:53 PM
ddisd's Avatar
ddisd
Default redtop battery support ?
I went out and purchased a redtop today. There was nothing wrong with the other battery but for $100 its a no brainer to me... Is there any tips from you guys on strapping it down? It does appear to have some sliding movement when held down with the pinch bolt in the front only...
Also, (even after reading this in a previous thread) - I dropped a socket into the depths below. Any pointers on getting it out without taking the battery tray out? I was going to buy a "magnet on a stick" type thing tomorrow, I can see it but can't reach it....
Thanks Everyone !!!
Old Jan 29, 2005 | 04:24 PM
Wolf1171's Avatar
Wolf1171
From: Winter Jam I and II Veteran, Bahama Jam 2005 Veteran
CI 4, 5, 7, 9 & 10 Veteran
St. Jude Donor '03-'05-'06-'08
I have the Optima Red Top and use the stock battery hold down, just in case. It does have a little more room to slide around then the stock battery does.
Old Jan 29, 2005 | 04:30 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
As for the dropped socket, it may be gone!! But you might get luckey and be able to get it
Old Jan 29, 2005 | 04:34 PM
Patches's Avatar
Patches
Note the larger hold-down block on mine in the second pic below. I got it free from Optima. It's much more stable.
Stock hold-down block
Optima block
Old Jan 29, 2005 | 04:40 PM
MarkT 2002's Avatar
MarkT 2002
Default Back Lip for Battery
I just replaced my stock battery, after 3 years of use even though it was still working, with the Red Top (same thoughts - no brainer). It fit fine, just remember there is a back lip at the bottom that holds the back of the down also.
MarkT
Old Jan 29, 2005 | 04:50 PM
jman1's Avatar
jman1
i got a different lock down block with my battery.. it was rounded and worked great
Old Jan 29, 2005 | 05:33 PM
LoneStarFRC's Avatar
LoneStarFRC
Same here.
jman1: Make sure your battery is slid all the way back so the rear lip is engaged before snugging down your hold down at the front. Also, if you happen to have a battery mat underneath the battery, I found that it raises it up too high to let the rear lip get a hold on the battery too. HTH
Robert
Old Jan 29, 2005 | 05:43 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
This is a great place isn't it. I had no idea there would be any issues regarding the battery hold down. Mine should probably be replaced this year so now I'll be aware of this.
Old Jan 29, 2005 | 06:11 PM
Laguna Blu's Avatar
Laguna Blu
After about 3 years in service and about 7 cycles of discharge & re-charge my Douglas battery went Kaput today. I charged it up fully last week and then trickle charged it and it barely turned over this morning. After a 1 hour drive with some highway time included I pulled back in my driveway and shut her off. Went to turn her back on and nothing, just clicking. Though I would have liked to buy a Red Top, I boosted the battery one last time and went down to the local gas station/garage. Though their distributor didn't sell the Optima, I "settled" on an AC Delco 78DT-6YR battery. I requested a dual terminal battery, which is exactly what I got. Hopefully I'll get a few years out of this one and eventually get around to finally getting an Optima. Wonder if these new batteries also have the leaking acid issue? Hmmmmmm.......
Old Jan 29, 2005 | 07:53 PM
Wolf1171's Avatar
Wolf1171
Thanks Everyone !!!
As for the dropped socket, once the battery is out you can take the 4 bolts out that hold the battery sill down to get to the bottom section where your socket is. It is a pain but you can retrieve.
Old Jan 29, 2005 | 08:14 PM
DsC5's Avatar
DsC5
Optima block
Old Jan 29, 2005 | 09:25 PM
Blue Lion's Avatar
Blue Lion
I have the 34/78 in my 2000 coupe. It fits perfectly with the factory battery "holder" keeping it in place.
I also dropped a screw doing my install. My neighbor had something that looked like a radio antenna and I used this to get the screw out.
Old Jan 29, 2005 | 09:45 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Mine came with a base that the battery sits on, that must be used to hold the battery in place, no movement.
Old Jan 30, 2005 | 12:20 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
You know, they only cost a few bucks. Why not do it right?
Old Jan 30, 2005 | 07:47 AM
FiberglassFan's Avatar
FiberglassFan
I too selected the larger 34/78 with 800 CCA rating. It came with 2 different hold-down clamps, but the factory clamp fit perfect and tight. I looked at the smaller one at the dealer and it looked like it would absolutely need a different hold down, because it is a slightly smaller footprint. Good luck getting it firmly attached......and retreiving your dropped tool.
Old Jan 30, 2005 | 08:31 PM
ddisd's Avatar
ddisd
Default redtop battery support follow-up
Got the socket out by removing the battery tray and using a magnet. I think it made the battery sit better once re-installed because now the battery is tight without and rocking movement like before. Of course used the Optima Battery hold down clip also. Thanks -
To redtop battery support ?
