Dead battery / check engine light
Old Jan 30, 2005 | 07:09 PM
C5inTemecula's Avatar
C5inTemecula
Default Dead battery / check engine light
Ok, so I have not been driving the Vette since the weather has been quite dreary, and I left the hatch open today while I detailed the interior. Ergo, battery goes dead.
I put it on my charger and she starts no problem, but I have a "check engine" light. Does this sound normal? It's on the charger now...
Thanks..
Old Jan 31, 2005 | 01:59 AM
JDAN1930's Avatar
JDAN1930
On my 2001 I had the check engine, reduced engine power, service active handling - this was the day my battery went dead - I replased it with a red top and everything was back to normal. Did not even loose a radio channel when I changed out the battery
Old Jan 31, 2005 | 02:57 AM
markcz's Avatar
markcz
Probably due to the dead battery, I had all kinds of weird stuff happen when mine went bad.
Try this:
-fully charge the battery
-start the car, let it run a few minutes
-clear/reset all codes on the DIC
If nothing comes back you're , if a new code comes up you might want to check it out.
Old Jan 31, 2005 | 07:01 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Try this:
The light can come on for a lot more than just engine related codes.....probably just the battery.
Paul
Old Jan 31, 2005 | 12:20 PM
C5inTemecula
Thanks guys - put a full charge into it and the CE light went off...was not relishing a trip to the dealer
To Dead battery / check engine light
