Jacking pucks
Old Jan 31, 2005 | 01:34 PM
WKMCD's Avatar
WKMCD
Default Jacking pucks
How many people are using jacking pucks? Are they reccommended?
Old Jan 31, 2005 | 01:40 PM
Husker67's Avatar
Husker67
I use 99 cent hockey puckets.
Old Jan 31, 2005 | 01:44 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
You need them if you are going to lift your baby....
Make your own
http://97vette.com/howto/liftpads/index.html
Or buy the vette ones premade - or I have heard the BMW ones work...
Old Jan 31, 2005 | 01:46 PM
GaDoll's Avatar
GaDoll
Cruise-In 11 Veteran
Default Jacking Pucks...
National Tire and Battery won't lift my car.....turned me down flat.....so I think there must be something good about these things. The cheap hockey pucks sound like a reasonable alternative.
Old Jan 31, 2005 | 02:03 PM
1KLRTOY's Avatar
1KLRTOY
www.hockeygiant.com .99 cents each,some washers & 1/4" eye bolts is all you need
Old Jan 31, 2005 | 02:04 PM
Merlin02's Avatar
Merlin02
I bought the square permanent hard plastic jacking pucks from Eckler’s. They’re the ones that you snap in and leave on the vehicle. I had to remove them when I had Andy at A&A install a set of his rocker rail savers. I couldn’t use both, as the rocker rail savers cover about half of the jacking puck hole in the frame.
Old Jan 31, 2005 | 02:52 PM
Mallory's Avatar
Mallory
I bought the ones for a Beemer. They work great. I think all 4 cost me $20 some odd dollars shipped from I think it was Bimmer.com. There is a thread with teh info on the site somewhere.
E
Old Jan 31, 2005 | 02:55 PM
srchief100's Avatar
srchief100
I use them - bought mine from a Forum Vendor. Good idea to take them with you on a trip in the event you find it necessary to lift the car, i.e. changing/repairing a tire.
Old Jan 31, 2005 | 03:02 PM
VETT2DY4's Avatar
VETT2DY4
Does anyone have a part number for the ones used on the BMW?
Old Jan 31, 2005 | 03:03 PM
Vetten Vayo's Avatar
Vetten Vayo
I wouldn't lift my Vette without them!!!!!!
Old Jan 31, 2005 | 03:05 PM
C5 4 ME's Avatar
C5 4 ME
Got mine from West Coast Corvettes.
Old Jan 31, 2005 | 03:18 PM
Bman's Avatar
Bman
St. Jude Donor '05
Hockey Pucks here..
Old Jan 31, 2005 | 03:41 PM
Dave1998's Avatar
Dave1998
Also , are they permanent or removable in event you need to be towed
as I heard these are also the points to tie down the car ?
Old Jan 31, 2005 | 03:56 PM
RoadReady's Avatar
RoadReady
Elite Engineering's are super trick!!
Old Jan 31, 2005 | 03:58 PM
Thunder7's Avatar
Thunder7
Not me. I have the Rocker Rails from A&A so I can lift the car anywhere along the side, NASCAR style. Works great, much easier, no worries.
Old Jan 31, 2005 | 04:03 PM
BigJoe's Avatar
BigJoe
http://forums.corvetteforum.com/show....php?t=1001090
Check these out. So pretty you can use them as paper weights... (they make them for C5s also).
Old Jan 31, 2005 | 04:05 PM
GR8-LIFE's Avatar
GR8-LIFE
If you have no rocker rail protectors you can get the new ones they have at Ecklers. They insert right in the lifting point and twist right in and stay there, like the BMW's. Plus they are not thick like some of the others you buy (or home make) so you can get the jack underneath them. I thought about getting them but I have rocker rail protectors and they obstruct their installation. Besides, the rails eliminate the problem anyway.
To Jacking pucks
Old Jan 31, 2005 | 04:07 PM
GR8-LIFE's Avatar
GR8-LIFE
Same here - got my rails from 21CMC when I did the TT. Rails makes thing real easy.
Old Jan 31, 2005 | 04:30 PM
C5Dawg's Avatar
C5Dawg
Default Pucks
I bought my from a vendor, they are plastic and snap in place so you always have them id needed.
Old Jan 31, 2005 | 04:39 PM
Purple Corvette Jim's Avatar
Purple Corvette Jim
What type of jack is being used ? Does anyone have a jack that can be carried in the back of the Vette. For those of us that don't have 'run flats"
