computer speed limit
Old Jan 31, 2005 | 07:34 PM
5JTL's Avatar
5JTL
Default computer speed limit
Can anyone tell me the computer cutout top speed on a stock '04 coupe?
Old Jan 31, 2005 | 07:47 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Didnt know there was one... But someone else might chime in...
Old Jan 31, 2005 | 07:49 PM
Mark VerMurlen's Avatar
Mark VerMurlen
There isn't one.
- Mark
Old Jan 31, 2005 | 07:50 PM
ErnieN85's Avatar
ErnieN85
Ther isn't any on a Corvette
Old Jan 31, 2005 | 07:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Actually, there is.
The PCM will only recognize speed readings up to 255mph.
Best of luck exceeding that!
Old Jan 31, 2005 | 08:00 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by Y2Kvert4me
Actually, there is.
Old Jan 31, 2005 | 08:03 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Actually, there is.
I do know you can't set the cruise control above 165 mph.
Old Jan 31, 2005 | 08:07 PM
juiced's Avatar
juiced
Yeah for about 5-6 minutes then you better hope there's a gas station nearby.
Old Jan 31, 2005 | 08:08 PM
GrayC5's Avatar
GrayC5
Are you referring to engine speed (Rev Limiter) or top end speed (mph)?
If you're referring to the the Rev Limiter it is around 6200 rpm for the LS1 engine and around 6600 rpm for the LS6 I believe. Just remember, the Rev Limiter only works when up shifting and not when down shifting.
CAJUNY2KC5's Avatar
CAJUNY2KC5
With a rest room, too.!!!
Old Jan 31, 2005 | 08:14 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Default Clarification
I'm not sure if the same PCM is used in other vehicles, but that max speed is a programmable function (with a tuning tool, not via the DIC options).
This feature could be used to limit the top speed if you (or GM) wanted to, and if the PCM is used on other platforms, may well be used as a limiter....But for Corvettes, it is factory-set to it's highest point, which happens to be 255mph.
Old Jan 31, 2005 | 08:17 PM
I don't think there is one. It's more a function of drag limitations than the computer I believe.
Old Jan 31, 2005 | 08:25 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
The stock coupes have a top speed (drag limited) of 185. The verts are about 10 mph less. Not sure about the ZO6s. Anyone have any data on those?
Old Jan 31, 2005 | 08:28 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Why does everyone say "drag-limited" anyways?
It's hp limited. It's easier to add hp and increase the top speed than it is to reduce drag.
Old Jan 31, 2005 | 08:45 PM
SilverBullit02's Avatar
SilverBullit02
let's start this over....... the rev limiter is set at a given RPM. It doesn't recognize speed. I believe all US manufactured cars & trucks have a speed limit programmed into there PCM's. It's usually set at the top speed rating for the STOCK tires. My C-1500 Silverado won't budge past 100 MPH, even though it's only turning 3'000+ RPM. The engine cuts out. Most Dodge's are set at 118 MPH, unless they have a factory equipped performance tire. The C5's PCM won't read over 255 MPH, but I believe the tires are rated at 252 MPH. So, if we go by that figure, the PCM is set at 252 MPH, max.
Old Jan 31, 2005 | 08:48 PM
robvuk's Avatar
robvuk
Also, "gear limited". 3.42 in 6th is around 260mph. I think a 4.10 is about 210mph.
Old Jan 31, 2005 | 08:51 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The stock Y rated tires are 186 mph max.
There are plenty of 200+ mph exotics that also run on Y rated tires. It is currently is the highest speed rating for any street tire.
To computer speed limit
Old Jan 31, 2005 | 08:58 PM
0EG@EnglandGreen
Supporting Tuner
You are drag limited.
At 180+, the front of the C5 wants to lift off, unless you get some diffusers under the car and a wing on the rear for downforce.
So unless you have your pilots license, I don't see how you can exceed 200+mph and stay on the ground in a stock C5, no matter how much HP you have.
Aerodynamics is your friend at those elevated speeds.
At 500rwhp and 2.73:1 gears, I should be able to break 200mph - but I will never try it in my car. Not without serious aero modifications.
EG
Old Jan 31, 2005 | 09:32 PM
leaftye's Avatar
leaftye
No! Diffusers and a rear wing would just cause the nose to lift even more! To keep the nose on the ground, you could utilize rake, a vented hood, vented wheel wells, a splitter, and dive planes.
Old Jan 31, 2005 | 10:44 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Willfulone
