[Z06] Build Out Sheet
Old Feb 1, 2005 | 11:11 AM
Green Hornet 2's Avatar
Green Hornet 2
Default Build Out Sheet
Does anyone know where they put the build out sheet, on a 2003 Z06, after the car left the assembly line? If I'm not mistaken they used to put it on top of the gas tank on the older models.
Old Feb 3, 2005 | 08:55 PM
tpocock's Avatar
tpocock
I believe it is in the right front frame rail
Old Feb 3, 2005 | 09:57 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
It is in the front bumper frame tube that is located behind the front (nose) fascia.
Old Feb 3, 2005 | 11:47 PM
LT1driver's Avatar
LT1driver
how do you get to it???
Old Feb 4, 2005 | 12:56 AM
FRISKY's Avatar
FRISKY
Remove the front fascia. It takes about 20-minutes to remove it.
Old Feb 4, 2005 | 10:18 AM
Green Hornet 2
Thanks................now I know where it is all I have to do is get to it.
Thanks again.................
To Build Out Sheet
