Can I program just one sensor?
Old Feb 1, 2005 | 02:06 PM
RDFLPIN's Avatar
RDFLPIN
Default Can I program just one sensor?
I want to program just one sensor (RR). I have a copy of the steps to program all the sensors. Do I have to program all the sensors just to do the RR, or can I program one sensor by itself (while its mounted on the wheel of course)? What is the best way to program just one (if it can be done)?
Old Feb 1, 2005 | 02:39 PM
ProDesign's Avatar
ProDesign
You cannot program just 1 sensor. Once you enter programming mode, you will be prompted to program (learn) each sensor one by one until all 4 sensors are programmed. Procedure is quite simple, so you should not be concerned about programming all 4 sensors.
Old Feb 1, 2005 | 02:40 PM
Dale98C5's Avatar
Dale98C5
I don't think you can do just one. It won't take long to do all four.
Old Feb 1, 2005 | 02:57 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
With a good, strong magnet and 4 working sensors, it takes a whole minute or so to walk around and do all 4.
Old Feb 1, 2005 | 05:33 PM
Got to do them all when you do this. Sorry, but it only takes about 2 minutes tops to do them all.
Old Feb 1, 2005 | 08:29 PM
ditty22's Avatar
ditty22
Iv asked this before but i also need to program 2 of my sensors yet and i forgot how it was done! Is there a way through the dic? sry to steal ur thread. ditti
Old Feb 1, 2005 | 08:34 PM
RCK1999's Avatar
RCK1999
There is a tech tip to take you through the programming process. Once you enter the programming mode, it will require that you follow a certain sequence of setting specific tires. If only one sensor needs re-training, you have to do all 4 to complete the training session.
Old Feb 1, 2005 | 09:53 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
If you don't find the tech tip, let me know. I printed the procedure from GM's tech manual. It's done very easily through the DIC. (and placing the magnet over each sensor at the appropriate time)
Mark
Old Feb 1, 2005 | 10:57 PM
GrayC5's Avatar
GrayC5
From C5 Tech Tips:
Resetting Tire Pressure Monitors
Old Feb 1, 2005 | 11:19 PM
ditty22's Avatar
ditty22
How large of a magnet will i need? thanks ditti
Old Feb 2, 2005 | 12:19 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
I have one of those magnet on a stick tools for picking up stray nails, screws, etc. - the magnet is about the same diameter as a hockey puck, but its only half as thick. It works for me...
Old Feb 2, 2005 | 12:44 AM
ditty22's Avatar
ditty22
Well i think i found a magnet big enuff for the job! http://cgi.ebay.com/ebaymotors/ws/eB...951091360&rd=1
To Can I program just one sensor?
