DTE Differential Strut Discussion
Old Feb 2, 2005 | 12:53 PM
RobWilson's Avatar
RobWilson
Default DTE Differential Strut Discussion
How many of you guys are using this differential strut? Please chime in. I'm getting ready to order a DTE Stage II differential with 3.90 gears. I'm going get their pinion support as well. I'm on the fence about this strut. I'd rather not spend the money, but I don't want break the differential and end up buying a new differential and *then* buy the strut.
For background, my car will probably see about a dozen passes a year at the drag strip (if that). I'll probably be doing 3500 to 4k launches on Nitto 305/35/18 drag radials. I'm putting down 437 rwhp and 400 rwtq (see sig for dyno graph). From previous experiences in an f-body, I know that it only takes one hard launch to break a rear end.
Let the discussion begin.
Old Feb 2, 2005 | 12:56 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Sounds like you will need one sooner or later. Might as well be sooner.
I should be receiving my diff strut from DTE today.
Ego-Trip's Avatar
Ego-Trip
Senior Member
CI 5-6-7-8 Veteran
Dude....just buy it. You are already spending well over $2k for the Stage II's, whats another $400 on the strut.
DTE just did a complete new package on my car and I had them do it. Think of it as insurance. If anything fails, its going to cost you way more than $400 to fix it. This could/should prevent most failures.
Old Feb 2, 2005 | 01:53 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Is yours an automatic? I've been waiting for my M6 strut.... Not that I need it that quick but I wanna see a bunch of pretty red metal!
Old Feb 2, 2005 | 02:02 PM
Dope's Avatar
Dope
Resident moron
I have the brace on my car too along with my DTE 3.90 rear.
Dope
Old Feb 2, 2005 | 03:21 PM
RobWilson's Avatar
RobWilson
I'd love to hear some feedback after you get it installed.
Old Feb 2, 2005 | 03:27 PM
RobWilson's Avatar
RobWilson
$400 is $400 that I don't want to spend unnecessarily. That is why I'm asking for feedback. In theory, it sounds like the right thing to do.
DTE says that this should help prevent failures, but I sure would like to hear from people that are using it. If everyone using it is happy with the purchase, then I'm in.
Old Feb 2, 2005 | 03:28 PM
RobWilson's Avatar
RobWilson
Dope,
How long have you had it? Any trips to the drag strip with it? Thanks!
Dope
Old Feb 2, 2005 | 06:37 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I'm running the Brace, but after my 2200 dollar explosion, i'm too scared and broke to take my car back to the drag strip!
Chris
Old Feb 2, 2005 | 06:45 PM
GTC's Avatar
GTC
Cruise-In V Veteran
Yes, mine is an A4. Phil and crew at DTE released the MN6 version before the A4, and have only recently released the A4 version. The A4 tranny is a lot larger than MN6, and hence there is a lot less space to have a diff strut. They only recently figured a way to make it fit.
stangkiller18, did yours explode with the diff strut installed?
Old Feb 2, 2005 | 07:38 PM
Stangkiller
No, i briefly experienced some wheel hop, at the drag strip, dusting off my tires approaching the line. It just went POP, i thought i just hadn't put it in gear all the way...but when it didn't move a second time, i shut it off we pushed it back, I knew i was in big trouble when the guy started moping up oil and picking up pieces of metal.
I was/am running yokohama's i believe...I'm going back to my kumho's once these are burned up.
Chris
Old Feb 2, 2005 | 09:18 PM
RobWilson's Avatar
RobWilson
What gear ratio and differential setup were you running at the time of the explosion?
Chris
Old Feb 3, 2005 | 02:00 PM
RobWilson's Avatar
RobWilson
Anyone else out there have the strut?
Old Feb 3, 2005 | 04:25 PM
Stangkiller
Running a z06 mn12, with stock 3.42 gears.
Old Feb 3, 2005 | 05:01 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I'm having my DTE strut installed next week while it's in the shop getting the rear main & left side diff. seals replaced.
To DTE Differential Strut Discussion
