Transmission leak
Old Feb 2, 2005 | 05:56 PM
Jamn's Avatar
Jamn
Default Transmission leak
I noticed a leak on the side plate on the drivers side of the transmission. I believe that the axel exits this plate. Is this something fairly simple to take apart and re-seal, or is this something better left to the dealer? I have heard that this is a common problem with the C5.
Old Feb 2, 2005 | 06:46 PM
00whitevette's Avatar
00whitevette
my 2000 started the same thing too. I think its a pan leak on the pan. Some one else know whats going on
Old Feb 2, 2005 | 06:55 PM
Jamn's Avatar
Jamn
How long has yours been leaking? I can see it plainly comming from the left side plate.
Old Feb 2, 2005 | 07:06 PM
csexton's Avatar
csexton
The drivers side diff. cover may be your problem. Many vettes have had this fix. There is a new o-ring from GM to help with the problem. Had mine done a year ago by dealer and it is holding fine.
Old Feb 2, 2005 | 07:14 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Very common problem. I am surprised there hasn't been a recall for this actually. I hope your car is still under warranty. If not I would give the General a call and complain that this should be done for free. Since you have heard that so many have had this happen. I had mine done 2 years ago and it's been great ever since. Good luck and keep us posted.
To Transmission leak
