Painting calipers
Old Feb 2, 2005 | 11:20 PM
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
Default Painting calipers
I'm interested in painting my calipers Nassua Blue. I was wanting input on where the majority thiks I should get an awesome matching color, how much paint, and the steps I might want to take in finishing the task. Anything would be helpful.
- Billy
Old Feb 2, 2005 | 11:24 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The 4oz can from Ken Fitchner or any parts counter should be enough and a good primer.
AR8007's Avatar
AR8007
I think it will look great, I would just get some spray paint that is real close and mask and spray, I will be doing this as soon as I can think of the best color for me.
Old Feb 3, 2005 | 01:23 AM
Dave1's Avatar
Dave1
St. Jude Donor '09
You can also use a small brush. No over spray and quick clean up. Post some pics when your finished..........
Old Feb 3, 2005 | 01:34 AM
Jason Blue Boost's Avatar
Jason Blue Boost
Billy, I have a set of blue powdercoated calipers off my car if your interested. They are very close to nassau blue. I'm upgrading to Wilwood's all the way around. What is your email so I can send you some pics?
Old Feb 3, 2005 | 06:52 AM
What was said above plus just make sure you clean the surface of the calipers very well. I sprayed on a lot of brake cleaner, then went over the area with some fine steel wool, then sprayed cleaner again. The result was a surface that the paint could really stick to. Good luck.
Old Feb 3, 2005 | 08:44 AM
ALLEGRO's Avatar
ALLEGRO
Depending on how dirty they are, I just cleaned mine with brake cleaner using a brush and applied three coats of color (black) and never took them off the car.
Take your time !
Old Feb 3, 2005 | 09:08 AM
Patches's Avatar
Patches
One of the classiest combos I've seen.
Old Feb 3, 2005 | 09:25 AM
love my car's Avatar
love my car
Wow Blue On Blue That Looks Sooo Nice
Old Feb 3, 2005 | 09:57 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Old Feb 3, 2005 | 10:25 AM
WGreen's Avatar
WGreen
Cruise-In I Veteran
I used a Rustoleum Metallic spray paint that I bought at Home Depot in Houston. I am not sure they still make it as it was 4 years ago.
Old Feb 3, 2005 | 10:54 AM
wpdjoey's Avatar
wpdjoey
looks
Old Feb 3, 2005 | 12:47 PM
MSGvette's Avatar
MSGvette
Very nice work
Old Feb 3, 2005 | 01:07 PM
vette_fanatic's Avatar
vette_fanatic
Take your time !
NICE !!!
I wonder how did u keep the "CORVETTE" on it, how did U cover these letters?
Old Feb 3, 2005 | 01:30 PM
WGreen's Avatar
WGreen
Cruise-In I Veteran
To get the corvette lettering to stand out after the caliper is panted, I used a firm sanding block with 180 grid to sand the paint off the letters.
Before I started sanding I put a strip of 2" masking tape on each side of the letters to protect the paint.
Old Feb 3, 2005 | 01:38 PM
98NassauBluC5
Thanks for the offer, guitarrocka205@netscape.net
Old Feb 3, 2005 | 01:55 PM
ALLEGRO's Avatar
ALLEGRO
Painted the letters silver with a paint-marker. Very easy !
Old Feb 3, 2005 | 01:57 PM
SilverRoadster00's Avatar
SilverRoadster00
I seem to remember someone saying you can srape the paint off the raised letters with a razor blade once you finished as well.
To Painting calipers
