Vert partition template
Old Feb 4, 2005 | 03:18 PM
junkmn's Avatar
junkmn
Default Vert partition template
I built my own Z06 partition and a friend saw it and wants one for his vert. Anyone have a template, know where to get one or would be kind enough to trace theirs for me?
Old Feb 4, 2005 | 03:19 PM
NSTG8R's Avatar
NSTG8R
http://www.fixedroofcoupe.com
http://www.fixedroofcoupe.com/blankc...ate&count=main
Old Feb 4, 2005 | 03:25 PM
junkmn's Avatar
junkmn
Unfortunately the template on fixedRoofCoupe.com is for the Z06 only.
Old Feb 6, 2005 | 02:07 AM
NSTG8R's Avatar
NSTG8R
if it's for the z06 it should fit the vert. email him and ask. I'm 98% sure.
Old Feb 6, 2005 | 05:28 AM
tonyh2000's Avatar
tonyh2000
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03
The 2% won this time. I tries the template in the vert and the top hits it and pushes it back.
can get one here
http://www.exoticvette.com/Exotic%20Vette/partition.htm
Old Feb 7, 2005 | 08:16 AM
falconsfan's Avatar
falconsfan
You can check them out over at PFYC.com as well, they have partitions for the z06 and vert.
http://www.pfyc.com/store/merchant.m...ry_Code=VTSPEC
Good luck!
Old Feb 11, 2005 | 08:09 AM
bmathews's Avatar
bmathews
The problem with the solid MDF partitions for the Verts is you have to take it out of you need to remove the center compartment cover. I would reccommend one of our ABS partitions as you do not have to remove anything to get the center cover out-- no hassles!!!
Old Feb 11, 2005 | 10:18 AM
Fastgenious's Avatar
Fastgenious
Sounds great if someone would trace it for you, but I think you should spend a few bucks and pay for that template yourselve. You spent a lot of money on your vette and few bucks more should not hurt you. Get used to spending $$$ on your vette because it never ends..
Old Feb 12, 2005 | 05:47 PM
bmathews's Avatar
bmathews
If you want a lightweight Vert partition-- try www.corvettepartitions.com
To Vert partition template
