where is the sensor for the outside Temperature?
Old Feb 4, 2005 | 03:20 PM
zvettez's Avatar
zvettez
Default where is the sensor for the outside Temperature?
where is the sensor for the outside temperature located?
Old Feb 4, 2005 | 03:23 PM
JoshVette's Avatar
JoshVette
Default double check
I could be wrong, but I thought I read somewhere, one's in the front brake air duct, and there's another on the dash that measures the sunlight and they put the two together to tell the temp???? Double check though..
Old Feb 4, 2005 | 03:35 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
It's attached to the radiator shroud up underneath the front.
Old Feb 4, 2005 | 03:37 PM
ALLEGRO's Avatar
ALLEGRO
Passenger side radiator support
Old Feb 4, 2005 | 03:38 PM
JoshVette's Avatar
JoshVette
I was close....ha
Is there another sensor on the dash that measures the sunheat??
Old Feb 4, 2005 | 05:28 PM
zvettez's Avatar
zvettez
thanks, can this be calibrated ?
Old Feb 4, 2005 | 05:37 PM
RCK1999's Avatar
RCK1999
No, unfortunately it can't. Am I to assume from your question that your external air temp. reading is inaccurate? If so, the sensor just needs to be replaced. You need to "wiggle" your hands down to unclip it, but it's an easy unplug the old & plug in the new. Its about an $8 part from a dealer. The formal name is an outside ambient air sensor.
PS - its a REALLY common problem.
PPS - only other replacement problem could be the plug the sensor clips in to could be corroded to the point of no return. If so, you will need to replace that as well. Again, cheap part.
Old Feb 4, 2005 | 05:51 PM
pdd000's Avatar
pdd000
[QUOTE=RCK1999] Its about an $8 part from a dealer. The formal name is an outside ambient air sensor.
QUOTE]
do you know the part number for this??
Old Feb 4, 2005 | 06:50 PM
kenrobb's Avatar
kenrobb
Had to replace the one in my son's 99. Part # I have is 10248414. We also had to replace the wiring connector as it had corroded. I found one at a local AC/Delco shop that was a bit cheaper than Chevy dealer. It's ACD# is PT374; GM# 12102747.
Old Feb 4, 2005 | 08:19 PM
RCK1999's Avatar
RCK1999
YUP
Old Feb 4, 2005 | 08:33 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
This is all good info!!! Into the archive it goes. Thanks.
To where is the sensor for the outside Temperature?
