"performance" hood seal
Old Feb 4, 2005 | 09:26 PM
kingrobby25's Avatar
kingrobby25
Default "performance" hood seal
Hello everyone, I just recently purchased a 99 black FRC and today i got my extra door sill seals and my hood seal. my nephew put on the hood seal and instead of putting it on the horizontal lip he put it on the vertical one. it looks like it still seals well and makes good contact with the hood. Would it be worth it to take it off and reapply it properly? thanks
Old Feb 4, 2005 | 09:29 PM
NSTG8R's Avatar
NSTG8R
I would think ti would protrude upwards past the fascia when the hoods up.
if it doesn't then i'd leave it alone.
Old Feb 4, 2005 | 09:30 PM
Blue Lion's Avatar
Blue Lion
I put mine on the other way, but I don't see any problems with the way he did it.
Old Feb 4, 2005 | 09:32 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
You will lose the 5hp gain if its installed wrong
Old Feb 4, 2005 | 09:36 PM
Poptops's Avatar
Poptops
IMHO, for all the good it will do, I'm afraid you could wrap it around your steering wheel and it would work just as well. Glad you're on the Forum and keep on modding!
Old Feb 4, 2005 | 09:38 PM
kingrobby25
Thanks, i was only curious about water and dirt being sealed out, i already have the type r stickers for the horsepower gains.
Old Feb 4, 2005 | 09:48 PM
CMCvette's Avatar
CMCvette
Good posts - so do these actually keep the engine cleaner? and do the door sill guards help with water spots in the sill area?
Old Feb 4, 2005 | 09:53 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The sill guards are worthless... the hood seal helps to keep the engine bay clean. I just hope you didn't pay too much for it... it's a 5 dollar item at home depot.. welcome to the forum..
Its a good idea to run any mods or consideration for doing anything on the forum .. Some one has probably done it before and can offer some tips... or better choices etc...
Old Feb 4, 2005 | 11:44 PM
jrose7004's Avatar
jrose7004
Old Feb 4, 2005 | 11:48 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I don't know. I put on the Home Depot Special hood seal, but, since I opened up the Fog Light Shrouds, I'm getting more dirt under the hood..
Old Feb 4, 2005 | 11:52 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Should be fine. It does help to keep the engine compartment cleaner and dry. If you try removing it, you will probably not be able to get it to stick again without new adhesive.
Old Feb 5, 2005 | 12:53 AM
FiberglassFan's Avatar
FiberglassFan
Only 5 HP, I thought it was about 12!
Old Feb 5, 2005 | 10:34 AM
Shall's Avatar
Shall
St. Jude Donor '05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-‘16-‘17
This is the second reference I have seen to the home depot product, but can't find anything with specifics. Can you point me in the right direction? I am assuming it is in the weatherproofing aisle. Might have to pick it up when I get my frost king sound proofing!
Thanks!
Old Feb 5, 2005 | 10:52 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
It sure does. I couldn't believe the difference when I put mine in.
Old Feb 5, 2005 | 01:22 PM
Z0SLIK's Avatar
Z0SLIK
Old Feb 5, 2005 | 09:21 PM
coast7's Avatar
coast7
Thanks E-T,
I installed your Home Depot "performance hood seal" mod. I would like to get a few more HP from the Home Depot "performance door sill seal" mod as well. Would the seal for the door sill be about the same diameter, or smaller?
Old Feb 5, 2005 | 09:46 PM
Sebring_C5's Avatar
Sebring_C5
To "performance" hood seal
