Turn signal intermittent?
Old Feb 5, 2005 | 12:29 AM
SmashF15C's Avatar
SmashF15C
Default Turn signal intermittent?
As some of you may have, I have (had) this problem. Most of the suggestions I got were to replace the flasher switch/module in the dash which apparently is a PITA.
Interestingly enough the problem seemed to get worse (occur more often) recently, then my right front DRL went out. Replaced it, and the left.
No turn signal problems since. I noticed that the filament they use is one and the same. I have no idea if it fixed it or not, perhaps some of you with the problem, go change your T signal/DRL bulbs and see what that does. Only about $5.
BTW, much easier to get out once you remove the headlight housing (3 screws) and the front hood stops (tape the nut to the threads and loosen/tighten later - keeps the same 'setting')
HTH
Smash
