Where is the exterior temp sensor located?
Old Feb 5, 2005 | 07:14 AM
Patman's Avatar
Patman
Default Where is the exterior temp sensor located?
Someone on LS1tech.com wanted to know where the sensor is located, and I tried to do a search on here, but the quick search on this forum does not work.
Can someone please post that diagram showing the exact location of the sensor?
Old Feb 5, 2005 | 07:25 AM
markcz's Avatar
markcz
Jack up the front end of the car, then slide under and look up at the lower corner of the radiator on the passenger side, it's right in there somewhere. If I remember right, it's a black plastic nub about the size of your pinky finger.
Old Feb 5, 2005 | 10:17 AM
Anthony01's Avatar
Anthony01
Hope this helps. GM has some sh*tty diagrams at times
Old Feb 5, 2005 | 10:44 AM
pdd000's Avatar
pdd000
any1 know the part number?
Old Feb 5, 2005 | 11:47 AM
Busted Knuckle's Avatar
Busted Knuckle
I'm almost positive the ambient air sensor is GM part # 10248414.
Have your dealer check that as I could be wrong but I don't think so.
Old Feb 5, 2005 | 12:14 PM
kenrobb's Avatar
kenrobb
And if you need the wiring connector that mates to the sensor it is:
ACDelco # PT374; GM# 12102747
My son's connector was corroded and sensor pin broke off upon removal. A bit of tight squeeze to get replacement in though.
To Where is the exterior temp sensor located?
