Hood Seal Install poll
Old Feb 5, 2005 | 10:45 PM
SmacZ's Avatar
SmacZ
Default Hood Seal Install poll
Well mine wasnt sticking well so Im going to start over but Im wondering..........
Did you guys install yours on the vertical surface or the horizontal surface?? Ive seen a few posts for each way...curious about the majority.
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Horizontal ... you definitely need a seal ... otherwise you'll have HP leaking out of your engine bay. And we all know how we hate to see HP laying wasted on the side of the road.
Old Feb 5, 2005 | 10:59 PM
breezn24's Avatar
breezn24
Vertical. Bought a single strip of the OEM seal GM uses on the sides of the hood, trimmed length to fit, and installed the same way (vertically) the seals on the side are installed. Works well.
Old Feb 5, 2005 | 11:06 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Clean it well with isoprophyl alcohol and stick it down horizontally - I've driven mine in all weather conditions and it's never come off or moved.
Plus it's good for an additional 17rwhp if attached horizontally...
EG
Old Feb 5, 2005 | 11:09 PM
RandW's Avatar
RandW
Denatured alcohol here & horizontal. 10' roll will do both lower door seals, too
Old Feb 5, 2005 | 11:15 PM
purrvert's Avatar
purrvert
The idea was to get more air with the filter, why cut some of it off????
Old Feb 6, 2005 | 04:54 AM
EFI-1's Avatar
EFI-1
Hey Randy, where can I find a 10' roll of the seal?
Old Feb 6, 2005 | 06:22 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Old Feb 6, 2005 | 06:34 AM
Z0SLIK's Avatar
Z0SLIK
Someone said you could but it at Home Depot. Is this true? Got a Blackwing coming in a few days and I am told I really need to do this.
Old Feb 6, 2005 | 06:45 AM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Clean the area well, and cut to size and stick it on. I've had mine on for almost 2 yr and no problems
Old Feb 6, 2005 | 07:02 AM
Z0SLIK's Avatar
Z0SLIK
Sponge Vette I have that stainless steel overlay where your's is yellow. I guess my question is will it stick to the stainless steel? Is that a blackwing I see in there?
Old Feb 6, 2005 | 07:13 AM
Sponge Vette
3M tape should stick to anything. Yes that's a blackwing
Just make sure that you clean it well, removing any wax or dirt first
Old Feb 6, 2005 | 09:03 AM
Steveo1c5's Avatar
Steveo1c5
I have a Blackwing and NO hood seal and NOT a drop of water can hit my filter, I will take some pic's and put them on my homepage to show the mod I did. I'll post when I upload the the pic's of the mod.
UPDATE..I have put some pic's of my filter mod on my home page scroll to the bottom. Here's the link.
http://home.swfla.rr.com/steveandcin...ome%20page.htm
Old Feb 6, 2005 | 09:23 AM
ZaydeZ06's Avatar
ZaydeZ06
I have the same set up, with the S/S overlay. Works fine.....
Old Feb 6, 2005 | 09:34 AM
BT-01-vette's Avatar
BT-01-vette
Cleaned the area well, then I used a thin layer of black silcone to keep the hoodseal in place. The 1st time I installed it, it started to peel away within 2 months with just the sticky tape on it.
Old Feb 6, 2005 | 12:49 PM
C5XTASY's Avatar
C5XTASY
I installed my hood seal with 3M double sided tape on both the vertical and horizontal surfaces. No problems in three years.
Ed
Old Feb 6, 2005 | 01:06 PM
FallenWhun's Avatar
FallenWhun
I used the bulbstyle weatherstrip from autozone. It works pretty good
To Hood Seal Install poll
Old Feb 6, 2005 | 02:59 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Vertical is too high, the hood won't sit right
Old Feb 6, 2005 | 03:12 PM
SmacZ's Avatar
SmacZ
Hmm I did mine vertical and didnt effect the way the hood sits....?
Old Feb 6, 2005 | 03:20 PM
Mine is installed on the horizontal surface. Been there for over three years and still holding strong.
