z06's options
Old Feb 7, 2005 | 12:20 PM
kardashim's Avatar
kardashim
Default z06's options
do any z06's come with power passenger seats?
(but it is possible to add the dual power sport seats..correct?)
and tire pressuer sensors can not be added..correct?
were memory seats standard or optional?
were electrochromic mirrors or optional?
what were the options for a 2001 z06?
still trying to figure it out, thanks...getting ready to make a purchase
but can't decide about a c5 loaded or a z06??
Old Feb 7, 2005 | 02:20 PM
SimonStern's Avatar
SimonStern
The power passenger seat was never an option AFAIK.
You can add tire sensors or the power seats later, but could never from the factory.
I believe both memory seats and electro mirrors were options. The HUD was stanadard.
I don't know all the options off the top of my head. Check out http://www.corvetteactioncenters.com for more info.
If you go Z06, I reccomend you look seriously at an '02+ The '01 came with a little less HP (385 vs. 405) and there were some problems with the piston rings.
Old Feb 7, 2005 | 04:36 PM
Mr. C's 5's Avatar
Mr. C's 5
Take a look in here as well. - C.http://www.c5frc.com/
Old Feb 7, 2005 | 06:03 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
2001 Z06
The ONLY options available were:
Memory Package
Floor Mats
Body Side Moldings
Electrochromic Mirrors
CD player
Front License plate frame
Millenium Yellow Paint
Museum delivery
Dual zone A/C was standard on the 2001 Z06
HUD was NOT available on a 2001 Z06
I am pretty sure (99%) the above info is correct.
As for the Pressure sensors, I have heard that they can indeed be used with a Z06. Supposedly you can edit the cars software to recognize them. Everything that is needed supposedly is in the car, you just need to use LS1 edit to "wake it up" and tell it that they are being put in use.
Of course the sensors are NOT there but you CAN put them in each wheel.
Old Feb 7, 2005 | 06:28 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
www.z06vette.com
Old Feb 8, 2005 | 07:52 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Yep - http://www.stopforce.com/RPO.html
(scroll down to Setting up tire pressure monitoring)
To z06's options
