Help running lights don't work!!!!!!!
Old Feb 7, 2005 | 06:55 PM
CN RED's Avatar
CN RED
Default Help running lights don't work!!!!!!!
I'm assisting a friend who stopped by with a running/turn signal light problem.
His front running light and turn signals won't come on. I checked all his fuses and they are all ok. His back signal lights work but they seem to flash a bit fast.
He is missing fuse #41 and I don't know what it does. It says it's the "RTD" fuse. but I don't know what that stands for.
Where should I start to see if everything is pluged up? I took the shroud off of the headlights and it appears as if everything is plugged in properly.
Could someone give me a hand with some advice?
CN RED
Old Feb 7, 2005 | 07:07 PM
VetteSiNz's Avatar
VetteSiNz
Check the bulb or the wire harnest - possibly not plug in all the way. Fast flash means one or two bulb is burnt out. Also check the flasher. If someone experience this problem, they chime in the correct answer.
Old Feb 7, 2005 | 08:12 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Ordinarily, if you have a fast turn signal it indicates a burned out bulb. It is odd that both of them went but not impossible. You could have damaged (burned through) connectors which is showing up as more and more common. I'd go after replacing the bulbs first and then work back from there.
Paul
Old Feb 7, 2005 | 08:15 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Old Feb 7, 2005 | 08:54 PM
CN RED's Avatar
CN RED
So let me get this right. If the light flashes fast that means the bulb is blown? But the rear signals work and the two fron don't. So when the rear bulbs blink fast is that a warning for the front bulbs being blown?
CN RED
Old Feb 7, 2005 | 09:18 PM
wpdjoey's Avatar
wpdjoey
sounds correct 2 me
To Help running lights don't work!!!!!!!
