Maf Plug?
Old Feb 10, 2005 | 05:29 PM
harleyrules's Avatar
harleyrules
Default Maf Plug?
How do you disconnect the wire that is attached to the MAF? I think that is what its called. The wire in front of the air bridge.
Old Feb 10, 2005 | 05:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Lift up on the clip and pull out.
Old Feb 10, 2005 | 08:43 PM
harleyrules
I lifted and removed the grayish color clip but still can't get it unplugged. Any other suggestions?
Old Feb 10, 2005 | 09:02 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Did you push down on the safety latch as well? Wiggle the plug back and forth while depressing the latch. Don't pull on the wires.
Old Feb 10, 2005 | 10:09 PM
Sixants's Avatar
Sixants
i dont't think it is the grayish clip you need to release. i would put that back on then unlatch the black safety clip.
Old Feb 10, 2005 | 10:11 PM
MY1STPEWTER's Avatar
MY1STPEWTER
If you have the security clip out (gray) then all you have to do is just pull it out. May have to wiggle it side to side a little bit but there's nothing else holding it in. Just had mine out two days ago putting a Halltech Stinger on. Mines a 01 and would guess they all the same, but cant say for 100%.
To Maf Plug?
