Frame Savers question?
Old Feb 10, 2005 | 11:40 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Frame Savers question?
I was wondering what the dimensions of the frame rail savers was. These are the savers that fit onto the frame under the rocker panels. Any help would be appreciated. TIA
Old Feb 10, 2005 | 11:58 PM
Ls1Rat's Avatar
Ls1Rat
about 3/8ths by 1 inch
easy enough to make
Old Feb 11, 2005 | 02:49 AM
SLO VETTE's Avatar
SLO VETTE
get the on'e sfrom a&a. best mod i've ever done. every morning when i slam down my driveway at .00001 mph and the frame savers save my azzz, i'm reminded of this....
Old Feb 11, 2005 | 09:58 AM
Stock Man's Avatar
Stock Man
Thanks LS1 Rat. Do you know how long they are?
Old Feb 11, 2005 | 02:50 PM
yellow viking's Avatar
yellow viking
I have both the frame savers and rocker rails. Get both, a must for lowered cars. This link will give install instructions and more.
https://www.aandacorvette.com/cart/s...sp?MainCatID=5
Old Feb 11, 2005 | 04:42 PM
Ls1Rat's Avatar
Ls1Rat
around 5 feet. just measure under your car. make sure you have them bend up in the front so the slide and don't catch
Old Feb 11, 2005 | 06:14 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I think you are referring to the rocker rails. Frame Savers do not attach "the frame under the rocker panels."
If you are actually referring to Frame Savers, let me know, and I'll go measure mine.
Old Feb 11, 2005 | 10:26 PM
Stock Man's Avatar
Stock Man
Yeah it's the rocker rails that I am interested in. Thinking of making some for my self. I like DIY. Thanks.
Old Feb 11, 2005 | 10:53 PM
TrackAttack!'s Avatar
TrackAttack!
St. Jude Contributor
Will these rocker rails still let you use the jacking pucks?
Old Feb 11, 2005 | 11:05 PM
yellow viking
I'm sure they will. The rocker rails are strong enough themselves to jack from.
Old Feb 11, 2005 | 11:18 PM
Stock Man's Avatar
Stock Man
Well I also found these but they are kind of pricey. But they have pads attached for jacking. http://www.madvet.com/shop?frame=1.165.4116
Old Feb 11, 2005 | 11:41 PM
MagRedSkull's Avatar
MagRedSkull
You do not need the rails with added jacking pads. The jacking pucks will not be needed with the A&A Rocker Rails. You can jack anywhere along the A&A Rocker Rails (I also place a piece of 2"x4" between the jack & rail).
Old Feb 11, 2005 | 11:55 PM
Morzoff's Avatar
Morzoff
I looked into a set of the above link, but $289.00 or what ever they were was to much
I went with the Andy's combo
Old Feb 12, 2005 | 01:25 AM
mrgil's Avatar
mrgil
Burnout
Default Rocker rails
Hey gang I think Stockman wanted the width and length of somebody's Aluminum ones.
mrgil
Old Feb 12, 2005 | 02:35 AM
Vette 4 Fun's Avatar
Vette 4 Fun
I have the A&A Rails, and they act in place of the jacking pucks
Old Feb 13, 2005 | 04:53 AM
Ls1Rat's Avatar
Ls1Rat
$290 ! for about 5 bucks worth of aluminum ?
Old Feb 13, 2005 | 05:30 AM
towo13's Avatar
towo13
BE VERRRRY CAREFULL!
A friend was jacking up his Z06, with rails. The car slipped off because the jack didn't grip the smooth rail....$3,000 in damage.
Old Feb 13, 2005 | 11:50 AM
Stock Man's Avatar
Stock Man
That's the very reason I only use the cross members for jacking. I was going to try the pucks but just didn't feel comfortable having the jack stands at such an angle to the body before jacking up the rear.
The rails are good for two post lifts that lift the front and rear in unison. But I wouldn't attempt to use this area with jack stands that the front must be jacked first then the rear.
To Frame Savers question?
