9011 and 9012
Feb 11, 2005 | 09:54 AM
9011 and 9012
ok in another thread i mentioned the use of 9011 and 9012 bulbs in place of the 9005 and 9006 bulbs we have from factory
and said id post pics
well i decided to make it an all out comparo i will post pics of
stock low and high beams
silverstars low and high
9011 and 9012 low and high
and euro t 84s stock wattage and high wattage versions with relays
low and high
it should put an end to the debate of what lights work best (no hids though)
i will try to finish up this weekend and post the results
Feb 11, 2005 | 08:27 PM
I'm especially interested in knowing how the 9011/9012 bulbs work. If they fit without mods, I'm going to try them out, but with HiR bulbs. If you don't know much about HIR bulbs, check out this site:
http://www.hirheadlights.com/
You can also check out the links I posted in the
C5 General Sticky .
Feb 12, 2005 | 06:36 AM
9011 and 9012
the only mod you have to do is the actual bulb has a thicker tab that goes in the light that needs to be grinded down like the standard lights 9005 and 9006 this is done to the bulb housing itself and not the headlight assembly
Feb 12, 2005 | 06:48 AM
St. Jude Contributor
Feb 12, 2005 | 08:57 AM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Feb 12, 2005 | 10:19 AM
Quote:
Originally Posted by JeepTJ
Feb 12, 2005 | 10:33 AM
Feb 12, 2005 | 11:01 AM
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Feb 12, 2005 | 11:39 AM
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Quote:
Originally Posted by 14U2ENV
Feb 12, 2005 | 11:58 AM
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
vadered...
Feb 12, 2005 | 12:05 PM
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Quote:
Originally Posted by Grumpy
vadered...
Feb 12, 2005 | 12:32 PM
2015 C5 of Year Finalist
To cute!!! A new lurk smilee. And I'll be waiting for the comparison. I am very interested in the HIR's.
Feb 14, 2005 | 07:16 PM
You get all those lights tested?
Feb 14, 2005 | 08:00 PM
Feb 14, 2005 | 09:01 PM
not yet
went to do it today and forget my camera at my house but i might get it done tomorrow
Feb 14, 2005 | 09:52 PM
Feb 15, 2005 | 08:39 PM
Did you get it done today?
Feb 15, 2005 | 09:15 PM
Feb 15, 2005 | 09:42 PM
Feb 15, 2005 | 09:49 PM
St. Jude Donor '03-'05-'06-'07
sweet....
