X-pipe installation info needed
Old Feb 12, 2005 | 03:23 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
Default X-pipe installation info needed
I see all the posts about X-pipes and I have what many would consider a dumb question. Is the installation of the X-pipe a bolt on operation or is it something that involves cutting and welding?
I presently have ZO6 Ti's on my vert and am considering an X-pipe.
Old Feb 12, 2005 | 03:29 PM
IM QUIKR's Avatar
IM QUIKR
Most X-pipes will have flanges to bolt up to the muffler pipes but the engine end needs to be cut and the X-pipe slides in place and is either welded or clamped in place. All in all an easy job. You can use a sawsall to cut the stock pipes.
Old Feb 12, 2005 | 03:39 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Let me be the first to tell you that this is not a dumb question...seeing how I asked the same question before I got my X pipe
The X pipe must be added to the engine side of the exhaust. I lined up the flanges on the muffler side and marked the engine side with a marker on the stock exhaust. Then I measured the amount of distance that the X pipe was to slide over the stock exhaust and subtracted it from my previous mark. Got out the saws-all and cut at that mark. Slid the X Pipe on...bolted up the flange end and then tightened down the clamps on the cut end...Done!!!
Peace
Willfulone
__________________
..................Click for
Old Feb 12, 2005 | 03:53 PM
RJP51's Avatar
RJP51
Default x pipe
No to steal the thread but can you pre-purchase a pipe for the engine side (pre-cut to length) rather than cutting the stock H pipe. I may want to put the stock H pipe back on when/if I sell.
Tks.
Rob
robflies@comcast.net
Old Feb 12, 2005 | 04:24 PM
IM QUIKR's Avatar
IM QUIKR
An X-pipe is $250-280. it's not worth removing. Just leave it in. if you really want to go back to stock you can usually buy a take off exhaust on EBAY cheaper than the X-pipe.
Old Feb 13, 2005 | 05:00 PM
FLACHUSNRET
Thanks for the info about the X-pipe. I have ZO6 Ti's on my '02 vert that is otherwise completely stock. It is not as loud as I had anticipated that it would be but I plan to install an X-pipe and a ZO6 cover on the airbox. Would these changes be worth it and would they give me a little better sound?
I am not interested in the loud sound of Borlas or anything that noisy.
Old Feb 13, 2005 | 05:30 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
I don't think the X-pipe will make it louder in fact it may quiet it down a little and remove the popping sound some experience on decel. I installed an X-pipe at the same time I installed my Ti's and there isn't much difference from stock. But I love the tips and the OE fit and finish and light weight of the Ti's. It should breath a lot better as well along with the X-pipe.
Old Feb 13, 2005 | 06:05 PM
georgec114's Avatar
georgec114
I don't think the X will buy you much, if any, performance.
The Ti's sound great as stock. If you were to go with GHL's or Borla's,
the X will reduce significantly the popping.
I've had three systems on two cars with and without X pipes.
I'm now with the GHL without the X pipe and will stay that way.
I was a little, OK alot, put off by the deceleration popping at first,
but I have grown to love the sound.
There is ZERO resonance as long as you're anywhere near the right
gear.
A little hint in case you do go with the X...Cut the H-pipe about 3/4
inch shorter than what they call for. There's plenty of overlap and it
will allow for a much easier install and a little forward/backward
adjustment.
And yes, if you ever go back to stock, just keep the H-pipe and go
to a Midas. I did this and for $60 they made a couple of short
pieces to clamp the stocker back in. $60 saved me $280.
...George
Old Feb 13, 2005 | 06:09 PM
jrose7004's Avatar
jrose7004
My Corsa X-Pipe was bolt on!
Old Feb 13, 2005 | 07:46 PM
All the X-pipes I have seen require you to cut the stock pipes and then install the X-pipe. The front of the X-pipe slips on the stock exhaust just behind the cats and the rear of the X-pipe just bolts up to the catback exhaust.
Old Feb 13, 2005 | 09:52 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
This is all good to know. I just installed my Ti's today and love the look. The sound will have to wait for a month to hear them. But I guess an X pipe would be next. That is if I don't like the sound of the Ti's. But I am pretty sure that I will. Good to know how the X pipe is instaled though.
To X-pipe installation info needed
