Recommend a Good Wiper Blade Refill
Old Feb 13, 2005 | 04:09 PM
Wisdom's Avatar
Wisdom
Default Recommend a Good Wiper Blade Refill
For a 2004 Coupe. I know it's a 22 inch refill, and it seems like I'll need to use a narrow blade. I got a year out of the original blades before they stiffened up. I've used various wiper refills on previous cars and they all seemed to last about 6-7 months in the Houston heat before needing replacement. What brands have you had good luck with regarding performance and lifetime? Or do you just get your refills from the dealer?
Old Feb 13, 2005 | 04:32 PM
JackTsDBG's Avatar
JackTsDBG
Bosch makes a very good long lasting blade and they are NOT nearly as expensive as PIAA.
Old Feb 13, 2005 | 05:26 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've used the Bosch blades with good success on my DD and my daughter's car for a couple of years. I get them at Autozone, and they're about $12 a piece.
Old Feb 13, 2005 | 06:02 PM
MAC5's Avatar
MAC5
If you want just refills, go with Trico 45-220, they run around $3.80 each and fit right in the original blade holders. Get mine at Advance Auto Parts.
Old Feb 13, 2005 | 06:05 PM
04Magnetic's Avatar
04Magnetic
Try these.
Trico Innovision
I just picked these up not too long ago for the Vette, I was so pleased with them, I ended up getting them for my Durango and my wifes Maxima also.
PepBoys has them.
Old Feb 13, 2005 | 06:07 PM
georgec114's Avatar
georgec114
Wipers? We don't need no stinkin' wipers.
Don't drive in the rain
Old Feb 13, 2005 | 06:14 PM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
I agree!!!!
I took mine off, saves weight! gained .26 hp!
Old Feb 13, 2005 | 06:50 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I've used Bosch and Trico. Both are excellent replacements
Old Feb 13, 2005 | 07:19 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Originally Posted by JackTsDBG
Bosch makes a very good long lasting blade and they are nearly as expensive as PIAA.
I just replaced the entire wiper with BOSCH. It seems to be better than what was there before. Don't use them much as I treat the WS and the rain just goes away.
Old Feb 13, 2005 | 09:51 PM
Wisdom's Avatar
Wisdom
Thanks for the inputs. I've used several brands from OReilly's and Autozone over the years, including Anco, but they never seemed to last. That's why I was surprised at the Vette blades staying good for so long. And it's a daily driver. Looks like I'll be looking for that Trico 45-220 or Bosch blades. I'll pass on the Innovision this year, maybe next year I'll try those. Thanks for the insight!
- Wisdom
Old Feb 13, 2005 | 09:57 PM
Wisdom's Avatar
Wisdom
For windshield treatments, for a short while in the early 90's my wife drove a Dodge Caravan that I treated with RainX. It worked great when it worked - but it seemed to always need a reapplication, and that seemed expensive (at least at the time). Once I decided to not use the product, it took a long time to get it off the windshield so it wouldn't cause problems. Bottom line: I liked that product, but the effort to remove it is why I don't use it on the Vette.
- Wisdom
Old Feb 14, 2005 | 12:34 AM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
Those are all okay, but step up to the PIAA silicone ones and you'll never go back. I run them on everything now, expensive but work better than anything I've seen (including Bosch micro-edge excel).
Bruce
Old Feb 14, 2005 | 04:35 AM
jdmvette's Avatar
jdmvette
Night Owl for life
I didn't bother with a refill, just replaced the whole assembly with a new one. I used tripledge from wallyworld and they work great.
Old Feb 14, 2005 | 09:06 AM
vetdude's Avatar
vetdude
I have the best luck with durability and performance from OEM blades. Like the original post says, they last longer than most aftermarket brands.
Old Feb 14, 2005 | 10:42 AM
Joe Diver's Avatar
Joe Diver
CF Enhanced Member
St. Jude Donor '06
There are wipers? Where are they and what are they for?
To Recommend a Good Wiper Blade Refill
