From: the GOCC are everywhere, even back from "band camp"
I went from Bosch to PIAA, won't use anything but PIAA silicone blades now. They also have a slightly cheaper version of the PIAA blade in more applications.
Bruce
I use the refill. There isn't much that can go wrong with the main portion of the blade and I have had some for as many years as I owned the car. However, sometimes it is just as cheap to replace the blade.
Bill
Can't imagine why you'd replace the whole arm if there's nothing wrong with it...just get the refill...plus it'll save you a couple of bux and be just as easy to put on ...
The wiper arm is where the wiper blade attaches. The refill just replaces the little strip of rubber in the blade. Most wiper blade manufacturers sell replacement blades or refills.
