Jacking Puck Question
Old Feb 15, 2005 | 11:22 AM
Hellobkk's Avatar
Hellobkk
Default Jacking Puck Question
Based on recommendations mentioned in the Forum,Just ordered a set of Jacking Pucks my 99 Vet from Elite Engineering.Question is can these pucks be left on vehicle or do they need to be removed after each use.
Old Feb 15, 2005 | 11:27 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
they look like the hang low so I would remove them. You wouldn't want it to fall out or get caught on something...
Old Feb 15, 2005 | 11:40 AM
rudolph schenker's Avatar
rudolph schenker
They are not intended to remain on. Remove them. Keep them in the car, in case you need work done you can reattach them!
Old Feb 15, 2005 | 11:41 AM
INaband's Avatar
INaband
CI 7-8 Veteran
They are small enough to store in the car somewhere.....
Old Feb 15, 2005 | 11:42 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It only takes about 1 sec. per puck to attach. You'll spend more time walking around the car then it takes to attach. They will come in a small box and could easily be stored in the car. They are also really cool paperweights!
Old Feb 15, 2005 | 12:10 PM
Hellobkk's Avatar
Hellobkk
Thanks for the info-will definately take you guys advice.
Tom
Old Feb 15, 2005 | 12:38 PM
DoomDRV's Avatar
DoomDRV
Default Make your own
Might be too late but if you have not ordered them look at making your own. Go to
www.97vette.com
and see if you like this alternative. I made the pucks but haven't used them yet - total cost about $20 Can.
Good Luck
Old Feb 15, 2005 | 12:42 PM
Southview's Avatar
Southview
I bought a set from BMW and leave them on.Still there after 6 months.
Old Feb 15, 2005 | 12:46 PM
I would recommend just keeping them in the car in a storage compartment and then when you need them, they can be attached quickly.
Old Feb 15, 2005 | 01:09 PM
Merlin02's Avatar
Merlin02
I could no longer use mine when I had Andy at A&A install a set of his Rocker Rail Savers. The Rocker Savers cover about half of the hole in the frame where the pucks attach.
Old Feb 15, 2005 | 01:28 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
So.....can you jack just using the rocker savers?
I've got them too but I haven't had the need to jack yet......
Old Feb 15, 2005 | 08:36 PM
leaftye's Avatar
leaftye
If you have them attached when you go over a big speed bump, you're going to screw up your frame!
Old Feb 15, 2005 | 08:43 PM
GrayC5's Avatar
GrayC5
That's what I do.
To Jacking Puck Question
