Proper Technique when using a lift
Old Feb 15, 2005 | 11:31 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Default Proper Technique when using a lift
Could someone please explain the proper technique that must be used to safely lift a vette on a two post lift? Is there an adapter necessary or can you simply use pucks? Are the rocker panels most suseptible to damage? thanks
Old Feb 15, 2005 | 11:39 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
I've had a vette, and a 2 post lifts, but not at the same time
You should be OK with just the pucks. All u have to do is make sure you contact the frame and not the rocker panels. Just go side to side a couple of times as the lift is close to touching the car, to make sure you make contact at the jacking points.
Old Feb 15, 2005 | 11:47 PM
GrayC5's Avatar
GrayC5
GM makes a J-tool (J 43625) to be used in lifting/jacking the C5. It is very similar to the billet aluminum lifting/jacking pucks that several of the Forum vendors sell here and these will work just fine also. Pucks along with care should always be used so as not to crack or damage the rocker or side panels.
Old Feb 16, 2005 | 12:16 AM
Bill Dearborn's Avatar
Bill Dearborn
GM recommends use of their pucks in the rear since there is little clearance around the lift point and the lift pad can come in contact with the body panel. In the front there is considerable room at the lifting point and you can easily get a lift pad seated against the frame without touching the body panel.
Bill
Old Feb 16, 2005 | 09:17 AM
1Patriot's Avatar
1Patriot
When I used the 2 post lift at my son's garage to change the oil and filter, we adjusted the adapters on the ends of the arms to compensate for the low rocker panels. No lifting pucks were required.
Old Feb 16, 2005 | 09:43 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
https://www.aandacorvette.com/cart/s...sp?MainCatID=5
get some of these...
Old Feb 16, 2005 | 09:45 AM
cl601amt's Avatar
cl601amt
When I got my car the fenders behind the front wheels were damaged from being on a lift, can anyone suggest a good shop in the Kansas City area to get this repaired?
Old Feb 16, 2005 | 01:29 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Originally Posted by Grumpy
The rocker rails are the best way to go.
You can lift from anywhere along the side with these.
I have had my vette up on my 2-post at least 100 times with no problems.
They also protect you from a lot of hazards you can encounter on the road.
more pic's from Andy's site.
http://www.megspace.com/cars/magred/RockerRail.html
Old Feb 16, 2005 | 01:51 PM
CorvettePartsBob's Avatar
CorvettePartsBob
This is Bob at Fichtner Chevrolet,
You can use pucks, but personally I don't think I would trust my 50,000 + car to something homemade. We have the GM/Kentmoore lift pads available for 79.95 a pair. This is the recommended tool from Chevrolet to safely lift your C5 or C6.
If you wish to order them give us a call at 800-234-5284 or email me at parts@fichtnerchevrolet.com
Bob
Old Feb 16, 2005 | 07:39 PM
Yello04's Avatar
Yello04
St. Jude Donor '05
What's the difference and benefit of the GM/Kentmoore pads over those offered by Elite Engineering? other than price and looks?
To Proper Technique when using a lift
