Pulling the wheels.......
Old Feb 16, 2005 | 12:21 PM
JetVette01's Avatar
JetVette01
Default Pulling the wheels.......
I know it hard to pull the wheels in a C5, but can it be done, stock suspension? Ive seen C5s in the 1.4 60 foot range not pulling the wheels, yet my buddy in his 00 camaro pulls a 1.6 60 foot with the wheels a foot off the ground. Suggestions......
Old Feb 16, 2005 | 12:32 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
solid axles are better for off the line... maybe that has something to do with it?
Old Feb 16, 2005 | 12:35 PM
T_Vert's Avatar
T_Vert
your buddy probally also has a drag suspension w/ much better weight transfer. The c5 is so fricking low w/ a very low CG and no weight transfer.
Dave
Old Feb 16, 2005 | 01:48 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
It may look cool and is done with stock suspension but...the lower the better for ET anyway.
Bone Stock F45 suspension here any happy with the WT:
1.52 60's on drs all day long
Old Feb 16, 2005 | 02:26 PM
Adrian-S's Avatar
Adrian-S
Originally Posted by ALLTHROTTLE&NOBOTTLE
Wow, are there still places in this country where you can dial seven digits on a phone and not include the area code to get an answer? Hope so, for the trophy shop... either that or they need to update their sign.
Old Feb 16, 2005 | 02:30 PM
JetVette01's Avatar
JetVette01
So your saying with a built driveline, slicks, and a 6k rpm launch, the front wheels wont leave the ground? What will happen?
Old Feb 16, 2005 | 02:32 PM
JetVette01's Avatar
JetVette01
Oh, and my buddy with the camaro, he has all completely stock suspension, (springs, shocks, etc.) Only subframe connectors and a built rearend.
Old Feb 16, 2005 | 03:08 PM
Cruise-In V Veteran
NCM Ambassador
Yes.......its called local
Old Feb 16, 2005 | 03:11 PM
robvuk's Avatar
robvuk
Maybe you should explain what you're trying to achieve. Pulling the front wheels off the ground or running the 60' in under 1.6? As ALLTHROTTLE has pointed out, he has no problem with 1.5's. If you want to pull the wheels, you will probably have to have a higher center of gravity or more power/tires yet.
Old Feb 16, 2005 | 03:14 PM
Cruise-In V Veteran
NCM Ambassador
I have an automatic and flash from idle~950 rpms...........as you see in the pic it hooks-n-cooks down the track. The OEM IRS limits the amount of travel plus this car is 3680# with me in it.
Suggest you go to some races with fast vette's and see what I mean
Old Feb 16, 2005 | 03:24 PM
AnteVenom's Avatar
AnteVenom
Daytona Jam 1 Veteran
I would also suggest if you have the F45 suspension that you set the selector to TOUR and for more weight transfer disconnect/drop the front sway bar.
Old Feb 16, 2005 | 04:19 PM
JetVette01's Avatar
JetVette01
Id like to pull a 1.5 60 or quicker. Its just that Id like some light under my tires with the good 60 foot numbers.
To Pulling the wheels.......
