Rear View Mirror LED Install Complete!
Old Feb 17, 2005 | 02:06 PM
  #41
TruUndrtkr's Avatar
TruUndrtkr
that looks real nice...
Old Feb 17, 2005 | 02:22 PM
  #42
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Help! Being he is going out of town for 3 weeks, tell me what I need for doing both the mirror and the door paness?
How may bulbs and do I need resistors for both or neither?
Old Feb 17, 2005 | 02:28 PM
  #43
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Originally Posted by WhiteC5Vette
What else can we LED? I would like to know before I place another order from Oznium for more LEDs. This guy is going to start wondering what I'm smoking. It seems everyday I place another order.
So, besides the rear compartment lights, front courtesy lights and now the mirror, along with the switches (doors, console, I/P) is there anything else we can LED?
Anyone do the underhood light?
I looked at that light, but it's welded on there I think. It was weird bulb. Besides, I don't think the heat would be good for the LED's.
I'm looking at doing the under the exterior door handles. Like the Beamer has when you walk up and unlock the doors. It's a cool little courtesy light.
Old Feb 17, 2005 | 02:36 PM
  #44
SpdKilz's Avatar
SpdKilz
I was also thinking about that, or possibly the inside door handles so when you turn off your car they light up and you can see the handles.
For the door panels, you will need 6 LEDs, but purchase these with the resistors. If you are going to do blue or white, I would recomend gettin gthe 3mm LEDs, that way you don't have to cut down the larger 5mm LEDs to fit into the holes (Onzium only offers blue and white 3mm LEDs right now...if you want a different color like red or green you will have to get the bulbs in 5mm and cut them down).
I would recomend getting at least 10 LEDs for just the doors, in case anything happens to one of the LEDs.
For the mirrors, (correct me if I'm wrong Dave) it appears you do not need to use the resistors, because you are merely exchanging the stock green/yellow LEDs with the new colored ones. You can use either 5mm or 3mm LEDs here, probably the 5mm ones would work best becuase they are closest to stock size. You will need twelve to do the mirror (six for each site).
All in all, I would order around 25 LEDs to do this project (always have a few extra). This should only cost about $15 dollars or so if you go to http://www.oznium.com/led
Carleton
Old Feb 17, 2005 | 02:43 PM
  #45
14U2ENV's Avatar
14U2ENV
Carleton
Just ordered 30 5mm and 20 3mm !
Looks like more fun to be had!
Old Feb 17, 2005 | 02:46 PM
  #46
EFI-1's Avatar
EFI-1
That's correct Carleton. :thumbsup:
Old Feb 17, 2005 | 04:22 PM
  #47
gairno's Avatar
gairno
Dave the mirror on the C5 is way different than the Z06. You have the buttoms on the front of the mirror and the C5 doesn't. Just the switch for turning the lights on. Thanks.
Old Feb 17, 2005 | 04:23 PM
  #48
Tom/99's Avatar
Tom/99
Old Feb 17, 2005 | 05:03 PM
  #49
MyVetteDream
Just saw this. I have halogen bulbs Oh well. Off to Auto Zone for Colored Bulbs!
Dave Q.
Old Feb 17, 2005 | 05:37 PM
  #50
EFI-1's Avatar
EFI-1
Sorry about that Gairno...you're just going to have to get a Z06 mirror.
Old Feb 17, 2005 | 06:16 PM
  #51
JTS97Z28's Avatar
JTS97Z28
That interior looks amazing!!! Bet it would look even cooler with a nice Avic-N1 navigation unit;-)
Ok my question for you that I have been curious about since my LED's are already on order as well. Do these LED's allow for dimming as all the lights do stock? I sat in my car today and nopticed all the interior lights including the door panel lights dim. Let me know.
Old Feb 17, 2005 | 06:26 PM
  #52
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
There are two different mirror offered on C5 vehicles. One is the base and has a switch at the bottom of the mirror; the other mirror is the auto dimming mirror and has two buttons on the lower front. The auto dimming mirror uses the six LEDs on each side for the map lights.
Old Feb 17, 2005 | 06:36 PM
  #53
EFI-1's Avatar
EFI-1
JT, yes they dim.
Old Feb 17, 2005 | 10:02 PM
  #54
gairno's Avatar
gairno
Dave, maybe I should just get a Z06. Hmmmmmmmmmmm. Thanks, Dave.
Old Feb 17, 2005 | 11:10 PM
  #55
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Great one more mod I have to do
Old Feb 18, 2005 | 08:44 AM
  #56
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old Feb 18, 2005 | 10:11 AM
  #57
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
wish I could solder...
To Rear View Mirror LED Install Complete!
Old Feb 18, 2005 | 10:18 AM
  #58
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have a 01 Coupe and it has the photochromatic mirror - better known as the auto dimming mirror, like EFI-1.
EG
Old Feb 18, 2005 | 11:18 AM
  #59
CUlookin's Avatar
CUlookin
Grumpy, I will solder it all for you if you promise not to lock any of my stoopid threads again...
Old Feb 18, 2005 | 05:06 PM
  #60
Villain C5's Avatar
Villain C5
looks good
