Anyone know the benefits (i.e. power increase) of installing a set of 1.85 rockers on my 2001 C5? It's a M6 with 4.10 gears, borla, blackwing, spec II clutch and aluminum flywheel...Thanks!
I installed them on my 99 with mildly ported ls1 heads, I also had prt exhaust and ls6 inake with stinger airfilter. I dynoed at 338rwhp and 338rwtq. This was with LS6 exhaust manifolds and A/F was 11.7.
Probably could have got 345hp with a leaner af and 355-360 with header. I just removed the 1.85 Rocker and installed a TR224/114 cam and dynoed at 370hp and 361tq. I still need to tune the car so that should put me at about 380hp, so basically with the same setup I picked up 25rwhp from the 1.85 to the 224/114 cam. Also mine is a M6 and I may be selling the 1.85 SLP rockers if you are interested.
I've been interested in the 1.8 Crane rocker set. If you search, especially on ls1tech, you'll find quite a bit of info about it. The idea is appealing to me. I don't see myself being happy with my car if it doesn't idle well, or if it is such a rough idle that it has to be raised 100 to 200 rpm's, in which case a bigger torque converter would be needed. But, I don't race my car at all, except for just messing around a little at stoplights. People seem to be getting good power/lowend torque increases with just a set of ported heads, and some basic bolt-ons and 1.8 or 1.85 rockers, and headers are good, (I'm installing those myself next week), But, if you do want "big" power increases, you must cam the car! Which, I haven't done with this car, but I don't think it would be that difficult if you have the tools/time/garage/patience/etc. I love my car, I don't even KNOW why I want to mod it. I must be obsessed!
