Curb Weight Question
Old Feb 17, 2005 | 10:42 PM
Tru_Ice's Avatar
Tru_Ice
Default Curb Weight Question
Anyone know the Curb weight of a fully loaded 02 Coupe?
Old Feb 17, 2005 | 11:24 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Well, base curb weight is 3246 lbs. Gasoline weighs about 7 lbs per gallon and a full tank is 18.5 gallons (130 lbs). Add up the other various and sundry fluids, probably another 50 lbs - I come out with about 3426 lbs.
I'd say in round numbers this is pretty close. Check out this web page, and do the math...
http://www.corvetteactioncenter.com/...2002specs.html
Old Feb 17, 2005 | 11:37 PM
2KFRC5's Avatar
2KFRC5
Curb Weight is the weight of a vehicle without passengers or payload, but including all fluids (oil, gas, coolant, etc.) and other equipment specified as standard.
3246lbs plus options.
Old Feb 18, 2005 | 07:30 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Feb 18, 2005 | 06:45 PM
RVers's Avatar
RVers
Interesting.
Incredibly, my 57 Chevy weighed the same. Except it had heavy guage steel body panels, an all cast iron engine, cast iron tranny and diff cases, crude iron frame, heavy front and back bench seats, heavy rear leaf springs and axel housings, crude steel A-arm front suspension, lots more glass and window mechanisms, heavier radiator, and so on. Despite all that, it did the 1/4 in 12.5 seconds (modded, of course).
One would think, almost 50 years later, that a state of the art, two-seat sports car, namely the Corvette, with more alloy and less steel and interior deadweight, would be lighter.
WTF?
Old Feb 18, 2005 | 06:53 PM
400hp's Avatar
400hp
Originally Posted by RVers
Interesting.
WTF?
Computer, power steering, power windows, air conditioning, catalytic converters, power seats, electronics and controls, 8 coils, air intake system, windshield washers, stereo system, MAF, coolant reservoir, a/c condensing coil, larger radiator, thicker glass, glass roof (more glass in general), more lights, etc.
Old Feb 18, 2005 | 07:14 PM
RVers's Avatar
RVers
Default Weight
Got your point, 400. But did I mention those massive 57 bumpers?
Plus, a lot of the tech stuff you listed weighs very little. For instance, electronics and controls, stereo, and related stuff probably weigh less than that old anchor of a 57 AM radio.
Also, I take off my C5 glass roof panel and stick in back cargo area by myself. You ever taken off a 57 Chev steel roof and lugged it around?
Just trying to figure it out.
Old Feb 18, 2005 | 09:19 PM
1Patriot's Avatar
1Patriot
Seems like a problem with records keeping or a bad set of scales. I owned a brand new 1956 Oldsmobile, Super 88 Holiday Coupe and it weighed a lot more than 2 tons.
Todays Corvettes weight much less than 2 tons as pointed out by other posters.
Old Feb 18, 2005 | 11:57 PM
early shark's Avatar
early shark
This is the first thing I did when I purchased my '02 coupe. Weighed it!
Drumroll please.......................3400lbs even!!!!!!
I ordered this car with 1SC,MN6,12disc, F45, 2 tops. This car was ordered fully loaded without BSM's and front license plate holder.
Old Feb 19, 2005 | 12:33 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
That's good to know. Mine is an '02 vert fully loaded F-45, 12 disc changer. So I wonder if the vert or the coupe is heavier?
Old Feb 19, 2005 | 03:21 AM
leaftye's Avatar
leaftye
Okay, 5 mph bumpers, foam, crash bar, bumper beams, dual airbags, airbag sensors, side impact beams, crush zones, lots of glass, but here are the big ones......
1. A stiff chassis
2. A quiet package
3. It's a bigger car
To Curb Weight Question
