I swear the radio volume goes down when I slow down??? say I am crusing at 70MPH on the highway...and the radio is at "x" volume...when I slow down coming off the interstate the volume seems to drop a little...
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
It's called SCV (Speed Compensated Volume). It the switch located behind the volume ****. All the way to the top, makes the radio much louder as the speeds increase, all the way to the bottom, turns off the feature.
I agree - reading the owner's manual is probably a good idea!
There's 4 settings for it. Off, 1, 2, and 3. Off will keep the sound at exact same volume. 1, 2 and 3 will increase/decrease the volume to match vehicle speed, at their corresponding level of intensity.
Hope this helps.
I've tried to use it to blow my speakers with no success. It sure is fun trying though
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by Derek Byrne
No thats the way its supposed to operate .The up/down switch behind the volume control can be adjusted to make this happen or not.
My daughters malibu also does that when you go faster the radio gets louder when you slow down it gets lower it's suppose to work like that you are not going nuts.
