Those Pucks
Old Feb 19, 2005 | 10:29 AM
RobsVett's Avatar
RobsVett
Default Those Pucks
I own a 98 Vett do i need those pucks to lift my Vett or are they not needed ? Thanks all
Old Feb 19, 2005 | 10:33 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I have one puck that I use when jacking manually... when using a lift 4 pucks are very nice to use.
VR
leaftye's Avatar
leaftye
If you don't have something like the A&A rocker rails, then pucks are necessary to jack from the rails if you don't want to mess up your rocker panels....and they also prevent the jack from sliding off the rails and causing a LOT more damage. If you jack from the subframes, then you don't need pucks. Make your pucks from hockey pucks and eyebolts unless you like spending money.
Old Feb 19, 2005 | 10:34 AM
SilverMN6's Avatar
SilverMN6
Not needed at all. They are just a project for your new toy, then some will call it a "MOD". I have never seen a shop with a lift that did not have wood or composition blocks to shim the lift arms when necessary. The Vette is not the only car that might need shims to lift properly.
jjlauro's Avatar
jjlauro
Yes you do need them. I got som plastic ones from a BMW dealership. They clip into the frame and don't have to be removed. They were only $5 each.
Old Feb 19, 2005 | 10:35 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Needed if you are lifting from the jacking points, (ie a post lift or a corner of the car) Not needed if you are using a floor jack and lifting from a cross member and using jack stands...
Make you own...4 hockey pucks .99 each and a #10 I hook...total cost about 5 bucks...
Peace
Willfulone
__________________
..................Click for
Old Feb 19, 2005 | 02:30 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I made some up and have never used them. I drive the car up onto some 2" extruded Styrofoam. 4 pieces. This gets the car high enough to get the jack under the front so that I can jack up the front by way of the front cross-member. I use a 2X6 to span the cross-member and then let the jack down once I have put a jack stand on either side of the jack. Then I go to the rear and do the same thing. It works great. You can get into the car and it's very stable. .02 deposited.
Old Feb 19, 2005 | 02:56 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
I would recommend getting a set of pucks, whether you get hockey pucks or a custom set is up to you. The cheapest and safest way to lift the Vette is to use a set of ramps and drive up on them and then raise the rear as pictured. I prefer to place the stands on the pucks in the rear though.
To Those Pucks
