power outlet not working
Old Feb 21, 2005 | 03:47 PM
Downtown's Avatar
Downtown
Default power outlet not working
I was attempting to hook up an XM Roady2 satellite to my 98' by going through the center arm rest power location. For some reason, it won't work. The power outlet by the ash tray works fine. I checked to make sure the cables were plugged in to the back of the outlet and they are. Does anyone have any ideas? Is there a fuse that controls this secondary power outlet?
Thanks for any suggestions.
Old Feb 21, 2005 | 03:53 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Fuse 1, I/P fuse block controls only the console accessory plug.
Old Feb 21, 2005 | 04:05 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I had the same problem and replaced the fuse and it worked fine. I did clean out the recepticle first as I don't think the prior owner ever used it at all. Rubber cap was off and it was full of "belly button lint."
Old Feb 21, 2005 | 04:10 PM
Downtown's Avatar
Downtown
Thanks for the quick replies. This might be stupid question, but where is the I/P fuse block? I know there is a fuse block near the battery. Is there one in the foot well passenger side?
Thanks again
Old Feb 21, 2005 | 04:20 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Yes, you will see a pair of latches on either side of the foot rest - open them, remove the foot rest and you'll see the fuse panel
Old Feb 21, 2005 | 04:29 PM
Downtown's Avatar
Downtown
Thanks everyone! That really helped. I will be taking a look at that and see if the fuse is blown.
Thanks again
Old Feb 21, 2005 | 06:04 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
Yup, he is correcto.
Old Feb 21, 2005 | 09:21 PM
wpdjoey's Avatar
wpdjoey
Old Feb 24, 2005 | 12:28 PM
FKING1's Avatar
FKING1
Same problem here. Thanks much!
Fred K.
Old Feb 24, 2005 | 03:41 PM
ericdwong's Avatar
ericdwong
Yup. Its 20 amp btw.
Old Feb 25, 2005 | 09:16 AM
Downtown's Avatar
Downtown
That fuse was blown. Replaced the 20amp fuse and the power works great! Thanks again.
To power outlet not working
